I was wondering if there is a command that frees up cached RAM
I often have 1GB cached RAM when I only have 1.7GB of RAM, and when I start an application like Minecraft (uses a lot of RAM) and the computer starts using 500MB of swap instead and becomes very very slow.
That's why I want to free up RAM before I start any games/apps.
Alvar
  • 17,038
To free pagecache:
echo 1 > /proc/sys/vm/drop_caches
To free dentries and inodes:
echo 2 > /proc/sys/vm/drop_caches
To free pagecache, dentries and inodes:
echo 3 > /proc/sys/vm/drop_caches
use with root permissions
özgür
  • 151
10
Cached RAM? Not really, but that's RAM managed by the kernel to cache disk reads, so it shouldn't impact your system's performance, in fact it should help it. You can change the way the kernel caches things, but I don't think you can explicitly free RAM that's currently used as a page cache. Generally newer kernels try to use as much free RAM as possible as a cache and free and re-allocate it as you start new processes, so you're generally going to see quite a lot cached. Why do you want to free it?
deej
  • 401
I have had issues with say my laptop with slowdowns and swap memory being used up at a high percentage, now there is a way to do so in the terminal, and even as a cron-job, i have done the latter for every 15 mins, and it does help, with still an occasional slow down depending on usage of my laptop. Depending on how you would like to do it, look at this link here Clean or disable the memory cache
and as I have said I have set it as a cron-job, so if you want to do it that way look for the solution that says "Make it a cron-job"
Matt
