I am using Ubuntu 16.04 LTS and want to write Japanese in all applications. I've installed mozc and it works in some applications but not in Eclipse or SzeneBuilder. I also tried to install qt4 ibus but it didn't help.
Thanks in advance!
EDIT1:
Output of env | grep -iE "im=|im_"
CLUTTER_IM_MODULE=xim
QT_IM_MODULE=fcitx
XMODIFIERS=@im=fcitx
IM_CONFIG_PHASE=1
QT4_IM_MODULE=fcitx
GTK_IM_MODULE=fcitx
Output of ibus read-config
SCHEMA: org.freedesktop.ibus.general
dconf-preserve-name-prefixes: ['/desktop/ibus/engine/pinyin', '/desktop/ibus/engine/bopomofo', '/desktop/ibus/engine/hangul']
use-system-keyboard-layout: true
embed-preedit-text: true
enable-by-default: false
use-global-engine: true
use-xmodmap: true
switcher-delay-time: 400
version: ''
engines-order: @as []
preload-engines: @as []
xkb-latin-layouts: ['ara', 'bg', 'cz', 'dev', 'gr', 'gur', 'in', 'jp(kana)', 'mal', 'mkd', 'ru', 'ua']
SCHEMA: org.freedesktop.ibus.general.hotkey
next-engine: ['Alt+Shift_L']
disable-unconditional: @as []
enable-unconditional: @as []
trigger: ['Control+space', 'Zenkaku_Hankaku', 'Alt+Kanji', 'Alt+grave', 'Hangul', 'Alt+Release+Alt_R']
previous-engine: @as []
prev-engine: @as []
next-engine-in-menu: ['Alt+Shift_L']
triggers: ['<Super>space']
SCHEMA: org.freedesktop.ibus.panel
x: -1
property-icon-delay-time: 500
y: -1
lookup-table-orientation: 1
show: 0
xkb-icon-rgba: '#415099'
auto-hide-timeout: 10000
show-im-name: false
follow-input-cursor-when-always-shown: false
custom-font: 'Sans 10'
show-icon-on-systray: true
use-custom-font: false
Output of dpkg -l ibus*
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
ii ibus 1.5.11-1ubun amd64 Intelligent Input Bus - core
ii ibus-anthy 1.5.6-1 amd64 anthy engine for IBus
un ibus-clutter <none> <none> (no description available)
un ibus-doc <none> <none> (no description available)
un ibus-el <none> <none> (no description available)
un ibus-googlepin <none> <none> (no description available)
ii ibus-gtk:amd64 1.5.11-1ubun amd64 Intelligent Input Bus - GTK+2 sup
ii ibus-gtk3:amd6 1.5.11-1ubun amd64 Intelligent Input Bus - GTK+3 sup
ii ibus-mozc 2.17.2116.10 amd64 Mozc engine for IBus - Client of
ii ibus-qt4 1.3.2-2build amd64 qt-immodule for ibus (QT4) (plugi
ii ibus-table 1.9.1-3ubunt all table engine for IBus
un ibus-table-arr <none> <none> (no description available)
un ibus-table-can <none> <none> (no description available)
un ibus-table-cns <none> <none> (no description available)
un ibus-table-com <none> <none> (no description available)
un ibus-table-eas <none> <none> (no description available)
un ibus-table-emo <none> <none> (no description available)
un ibus-table-erb <none> <none> (no description available)
un ibus-table-ipa <none> <none> (no description available)
un ibus-table-jyu <none> <none> (no description available)
un ibus-table-lat <none> <none> (no description available)
un ibus-table-qui <none> <none> (no description available)
un ibus-table-rus <none> <none> (no description available)
un ibus-table-scj <none> <none> (no description available)
un ibus-table-str <none> <none> (no description available)
un ibus-table-tha <none> <none> (no description available)
un ibus-table-tra <none> <none> (no description available)
un ibus-table-viq <none> <none> (no description available)
un ibus-table-wu <none> <none> (no description available)
un ibus-table-wub <none> <none> (no description available)
un ibus-table-yaw <none> <none> (no description available)
un ibus-table-yon <none> <none> (no description available)
