I have recently installed Ubuntu 14.04 LTS on a Compaq Presario C504EA (wiping off the old Windows Vista install), and I am trying to enable Bluetooth.
I have had a look on rfkill list all, the results are:
0: hp-wifi: Wireless LAN
Soft blocked: no
Hard blocked: no
1: hp-bluetooth: Bluetooth
Soft blocked: no
Hard blocked: no
2: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
When you open System Settings | Bluetooth, it says Bluetooth is disabled, whether Bluetooth is switched to on or off.
Edit: the results of uname -a; dmesg | egrep -i 'blue|firm'
rob@rob-Presario-C500-RT154EA-ABU:~$ uname -a; dmesg | egrep -i 'blue|firm'
Linux rob-Presario-C500-RT154EA-ABU 4.2.0-36-generic #42~14.04.1-Ubuntu SMP Fri May 13 17:30:34 UTC 2016 i686 i686 i686 GNU/Linux
[ 0.103205] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
[ 22.560190] Bluetooth: Core ver 2.20
[ 22.560311] Bluetooth: HCI device and connection manager initialized
[ 22.560319] Bluetooth: HCI socket layer initialized
[ 22.560324] Bluetooth: L2CAP socket layer initialized
[ 22.560334] Bluetooth: SCO socket layer initialized
[ 22.668875] Bluetooth: RFCOMM TTY layer initialized
[ 22.668892] Bluetooth: RFCOMM socket layer initialized
[ 22.668900] Bluetooth: RFCOMM ver 1.11
[ 22.788640] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 22.788647] Bluetooth: BNEP filters: protocol multicast
[ 22.788656] Bluetooth: BNEP socket layer initialized
[ 31.878953] b43-phy0: Loading firmware version 666.2 (2011-02-23 01:15:07)
Results of lsusb:
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Any thoughts? Many thanks
