I would like yo know if there is any method to provide execution permission to all files created under a specific directory by default.
i.e,
If I create a file say foo.sh under a directory fooscripts, it should have execution permission by default. But if I create same file outside fooscripts it should be as usual.
Severus Tux
  • 10,126
Using inotifywait
As mentioned, you can use inotify-tools (inotifywait) to watch a specific directory for changes, for example by the script below, and subsequently set new files executable recursively.
The script uses the inotifywait -command, which is triggered by specific events, set by the -e -option. Luckily the command can be used in combination with multiple event types.
Since you want the files inside the directory to be executable, in the script, two events are set:
-e move
which will notice files moved into the directory, and
-e create
which will notice new files created inside the directory.
Furthermore, the options:
-m -r
are to make the command run indefinitely ("monitor") and recursively in the directory, while:
--format '%w%f'
outputs the directory (path to the file, %w) plus the filename (%f) that caused the event.
More on options of inotifywait can be found here, or, as always, in man inotifywait
The script
#!/bin/sh
# you might want to change the directory below into the targeted directory
DIR="/home/jacob/Bureaublad/test123"
inotifywait -m -r -e move -e create --format '%w%f' "$DIR" | while read f
do
  chmod +x "$f"
done
How to use
  1. You will probably have to install inotify-tools first:
    sudo apt-get install inotify-tools
  2. Copy the script into an empty file, save it as set_executable.sh
  3. In the head of the script, set the path to the targeted folder:
    # change the directory below into the targeted directory
    ...and test-run the script from a terminal.
  4. If all works fine, add the script to Startup Applications: Dash > Startup Applications > Add.
Note
Note that notifywait acts on changes (events). That implies that files that were added or created before the script ran will not be effected. Nor will it re- set the files executable if you manually and deliberately set them not to be executable, while they are inside the targeted directory.
Jacob Vlijm
  • 85,475
No. You could use inotify to watch the directory and chmod new files.
Here is how to find out about inotify:
man -k inotify
for i in $( man -k inotify | awk '{ print $1 }' ) ; do
    man $i
    read -p "Print?: " ans
    if [[ "x$ans" = "xy" ]] ; then
        man -t $i | lpr -J $i
    fi
done
# sr is from surfraw, Shell Users Revoultionary Front Rage Against the Web
sr google inotify
waltinator
  • 37,856
