19
I'm relatively new to Linux and have only used Ubuntu briefly while saving up for a Windows key. I wanted to try out Ubuntu 16 as a replacement for Mac OS X so for an iMovie replacement I wanted to try KdenLive. I was looking around on the website and I couldn't find anything on how to install through the terminal or software center since they are what I'm familiar with. This https://launchpad.net/~kdenlive/+archive/ubuntu/kdenlive-testing is the only page I can find and I haven't a clue how to get packages using pages like this. Thanks in advance!
You can install it through the software centre, just search for "Kdenlive" in the software centre, and click Install. You can also install it through the terminal by typing
sudo apt-get install kdenlive
That's it.
Note that you will not get the very latest version by doing this - if you want to have the latest version, you'll need to add the PPA. Do this by typing
sudo apt-add-repository ppa:kdenlive/kdenlive-stable && sudo apt-get update
in a terminal before installing it through the software centre or using apt-get install
Jonas Czech
  • 4,047
Type this: sudo add-apt-repository ppa:kdenlive/kdenlive-testing
and then press 'Enter when you are asked to'
Then type this command:sudo apt-get update && sudo apt-get upgrade
Then sudo apt-get install kdenlive
That's it you are done with it.
There was a small pop-up link leading you through the process of installing stated as 'Read about installing', This same process applies for each and every other 'PPA' named as Personal Package Archive.
You can learn more about PPA here.
