I am trying to install xbacklight using
sudo apt-get install -y xbacklight
but getting error related to mysql.After running above command a new window pop up to set password for mysql.But after setting it shows following error in terminal.
Reading package lists... Done
Building dependency tree
xbacklight is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 1534 not upgraded.
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up mysql-server-5.6 (5.6.30-0ubuntu0.15.10.1) ...
/usr/sbin/mysqld: Can't read dir of '/etc/mysql/conf.d/' (Errcode: 2 - No such file or directory)
Fatal error in defaults handling. Program aborted
AppArmor parser error for /etc/apparmor.d/usr.sbin.mysqld in /etc/apparmor.d/usr.sbin.mysqld at line 9: Could not open 'abstractions/mysql'
I have installed xbacklight in 14.04 Ubuntu.How should I do it in 15.04?
js_248
  • 147
Run the following commands:
sudo apt-get update
sudo mkdir /etc/mysql/conf.d
sudo apt-get -f install
Then, I seriously suggest you update your software before doing anything else. Run one of the following commands:
sudo apt-get upgrade
or, recommended:
sudo apt-get dist-upgrade
Click here if you don't know the difference.
mchid
  • 44,904
  • 102
  • 162
