I recently upgraded my machine from 12.04LTS to 14.04LTS and discovered that my resolution is stuck at 800x600; the Display setting does not show any other resolution available. I strongly suspect that a faulty video driver is at fault since I tried loading an application that draws 3D objects and it runs ridiculously slow.
I have currently tried the following:
- Force a higher resolution via GRUB: didn't seem to do anything
- Install nvidia-340 from xorg-edgers: no change, and it seemed to have changed multiple modules to the version from this ppa
- Use the Additional Drivers setting to install other drivers: tried all of the drivers listed and none of them worked: 340.96 352.63 352.79 355.11 358.16 361.45.11 364.19 Noeveau (some of them are proprietary and others open-source)
- Reset
xorg.conf: when the OS upgraded to 14.04LTS it automatically backed up the original file but did not create a new one. I have experimented with creating a blank file but that doesn't change anything.
At this point I'm at a loss as to what else there is to try.
Command outputs that might be helpful:
username:~$ sudo lshw -C display; lsb_release -a; uname -a; xrandr
*-display UNCLAIMED
description: VGA compatible controller
product: GM107 [GeForce GTX 750 Ti]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:04:00.0
version: a2
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list
configuration: latency=0
resources: memory:fa000000-faffffff memory:e0000000-efffffff memory:f0000000-f1ffffff ioport:d000(size=128) memory:fb000000-fb07ffff
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 14.04.4 LTS
Release: 14.04
Codename: trusty
Linux psych-lab-va-linux 3.13.0-87-generic #133-Ubuntu SMP Tue May 24 18:32:09 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 800 x 600, current 800 x 600, maximum 800 x 600
default connected primary 800x600+0+0 0mm x 0mm
800x600 75.0*
username:~$ lspci -k | grep -EA2 'VGA|3D'
04:00.0 VGA compatible controller: NVIDIA Corporation GM107 [GeForce GTX 750 Ti] (rev a2)
Subsystem: eVga.com. Corp. Device 3753
04:00.1 Audio device: NVIDIA Corporation Device 0fbc (rev a1)
UPDATE
After reviewing the Xorg log files I realized that it was trying to load the nvidia driver but couldn't because it couldn't be found, so I followed this answer and rebooted. It didn't solve the problem, but at least I got a different problem; I can get to the login screen, but I encounter a login loop after entering the credentials. The Xorg log file shows that the nvidia driver is loaded but gives an error: "Failed to initialize the NVIDIA kernel module". I've tried the debugging steps for a login loop (checking Xauthority and /tmp) but nothing has worked. modprobe nvidia-352 returns with no errors.
