I attempted to install Ubuntu alongside Windows 7. (Intel i5 2300 H67 chipset)
Unfortunately, after a seemingly successful installation I got the message:
GRUB: “invalid arch independent ELF magic” grub rescue>
Another answer here suggests I should enter these commands below, which should be customised for my own partitions.
sudo apt-get install grub-efi-amd64
sudo mount /dev/sda3 /mnt
sudo mount /dev/sda1 /mnt/boot
sudo grub-install --root-directory=/mnt /dev/sda
My partitions are...
   Device Boot      Start         End      Blocks   Id  System
/dev/sda1   *        2048      206847      102400    7  HPFS/NTFS/exFAT
/dev/sda2          206848   819202047   409497600    7  HPFS/NTFS/exFAT
/dev/sda3       819202048  1228802047   204800000    7  HPFS/NTFS/exFAT
/dev/sda4      1228804094  1953523711   362359809    5  Extended
/dev/sda5      1228804096  1936926719   354061312   83  Linux
/dev/sda6      1936928768  1953523711     8297472   82  Linux swap / Solaris
However, I'm a bit unsure how I can adapt those commands above because I want to be able to dual-boot with windows 7. (if those commands are appropriate for me anyway).
Given my partitions above, how can I get GRUB to give me a dual boot option?
thanks
Kim
  • 391
I managed to fix this by using the live cd and entering the commands:
sudo mount /dev/sda5 /mnt
I can successfully access both Ubuntu and Windows.
Kim
  • 391
