Everytime I reinstall apache2 it just doesnt work WORKS. sudo ufw allow in "Apache Full" gives Skipping adding existing rule Skipping adding existing rule (v6)
Also while trying to install php7.0-mbstring, i get this error:
 php7.0-mbstring : Depends: php7.0-common (= 7.0.4-7ubuntu2.1) but 7.0.6-13+donate.sury.org~xenial+1 is to be installed
E: Unable to correct problems, you have held broken packages
I have tried to follow the instructions on how to fix broken packages but even tht has not helped. Hope someone can atleast help me find the right fault.
Hedwig
  • 31
This is no error, use sudo ufw status to check it, it simply tells you that a rule for that already exists.
Best is to get a bit familiar with ufw on command line by reading the manual
As for the second problem you added, make sure you enable the package sources in System Settings --> Software & Updates then run an:
sudo apt-get update
sudo apt-get -f install
sudo apt-get dist-upgrade
Running the first and third command mostly keeps you out of trouble when trying to install something new. As well you only need to use php-mbstring thats the virtual package for the installation. So this will suffice:
sudo apt-get install php-mbstring
Videonauth
  • 33,815
Ok, I had exactly the same problem. My answer is not very clean but it does work.
  • First I installed aptitude: sudo apt-get install aptitude
  • Then I asked aptitude to install php-mbstring: sudo aptitude install php-mbstring
  • It asked me to make some choices to install it, so I didn't accept the first one (that was, "don't install php-mbstring"), I accepted the second one that was "downgrade a bunch of php modules to the right one
  • Now I have php-mbstring
\o/
stadja
