I noticed Xcode has released a (non-snapshot) xCode download for Ubuntu.
I looked for an article on how to install it and I couldnt find anything.
Can anyone advise how to do this?
To install Swift on Ubuntu, you are going to have install a component called clang:
Go to the terminal and type:
sudo apt-get install clang
If you installed the Swift toolchain on Linux to a directory other than the system root, you will need to run the following command, using the actual path of your Swift installation:
export PATH=/path/to/Swift/usr/bin:"${PATH}"
You can verify that you are running the expected version of Swift by entering the swift command and passing the --version flag:
swift --version
Apple Swift version 2.2-dev (LLVM ..., Clang ..., Swift ...)
The -dev suffix on the version number is used to indicate that it’s a development build, not a released version.
