Is the AMD Radeon 6450 blacklisted for 11.04? I get an error message saying my hardware is not compatible for Unity. I have an i5-processor, DL-67 Intel Motherboard,4 GB RAM, and 1 GB Radeon 6450 Graphics... (New to Linux!)
Anonymous
  • 11,979
Nitish
I am using ATI HD4870 and while I was using Ubuntu 11.04, I also had your issue. But installing the official driver from AMD site:
here
is the link to the 64bit driver of your card. Make sure you have Ubuntu 11.04 64bit, otherwise download the 32bit version. Read the release note there for useful info. After download run the following command in the terminal, from your download location:
 sudo sh ./ati-driver-installer-x86.x86_64.run
Follow the instruction and you should be fine. I recommend you keep the driver on your disk, because every kernel update, or when you see that the shell does not start up properly after a reboot, you need to reboot into low graphics and re-run the above command.
You can also force the driver to be installed:
sudo sh ./ati-driverinstaller-x86.x86_64.run --force
For uninstall:
sudo aticonfig --uninstall
Hope it helps
bioShark
  • 4,315
