I cannot get any downloads finished, when it gets about 5mb downloaded, i get the Permission Denied error
transmission is running on debian-transmission
This answer does NOT work for me
Also, the disk i am writing on has read and write permissions for everyone, but the owner is set to the sudo user
Do not hesitate to ask if you need more info!
setting.json:
"alt-speed-down": 50,
"alt-speed-enabled": false,
"alt-speed-time-begin": 540,
"alt-speed-time-day": 127,
"alt-speed-time-enabled": false,
"alt-speed-time-end": 1020,
"alt-speed-up": 50,
"bind-address-ipv4": "0.0.0.0",
"bind-address-ipv6": "::",
"blocklist-enabled": false,
"blocklist-url": "http://www.example.com/blocklist",
"cache-size-mb": 4,
"dht-enabled": true,
"download-dir": "/mnt/raid1/downloads",
"download-limit": 100,
"download-limit-enabled": 0,
"download-queue-enabled": true,
"download-queue-size": 5,
"encryption": 1,
"idle-seeding-limit": 30,
"idle-seeding-limit-enabled": false,
"incomplete-dir": "/var/lib/transmission-daemon/Downloads",
"incomplete-dir-enabled": false,
"lpd-enabled": false,
"max-peers-global": 200,
"message-level": 1,
"peer-congestion-algorithm": "",
"peer-id-ttl-hours": 6,
"peer-limit-global": 200,
"peer-limit-per-torrent": 50,
"peer-port": 51413,
"peer-port-random-high": 65535,
"peer-port-random-low": 49152,
"peer-port-random-on-start": false,
"peer-socket-tos": "default",
"pex-enabled": true,
"port-forwarding-enabled": false,
"preallocation": 1,
"prefetch-enabled": 1,
"queue-stalled-enabled": true,
"queue-stalled-minutes": 30,
"ratio-limit": 2,
"ratio-limit-enabled": false,
"rename-partial-files": true,
"rpc-authentication-required": true,
"rpc-bind-address": "0.0.0.0",
"rpc-enabled": true,
"rpc-password": "",
"rpc-port": 9091,
"rpc-url": "/transmission/",
"rpc-username": "diadras",
"rpc-whitelist": "*",
"rpc-whitelist-enabled": true,
"scrape-paused-torrents-enabled": true,
"script-torrent-done-enabled": false,
"script-torrent-done-filename": "",
"seed-queue-enabled": false,
"seed-queue-size": 10,
"speed-limit-down": 100,
"speed-limit-down-enabled": false,
"speed-limit-up": 100,
"speed-limit-up-enabled": false,
"start-added-torrents": true,
"trash-original-torrent-files": false,
"umask": 2,
"upload-limit": 100,
"upload-limit-enabled": 0,
"upload-slots-per-torrent": 14,
"utp-enabled": true
output of ls -l /mnt/raid1/:
diadras@Desktop:~$ ls -l /mnt/raid1/
total 52
drwxrwxr-x   2 diadras             diadras              4096 mei 13 16:21 Backup
drwxrwx---  10 debian-transmission debian-transmission  4096 mei 26 10:52 downloads
drwx------   2 root                root                16384 mrt  3 23:35 lost+found
-rw-------   1 diadras             diadras                82 mei 26 16:47 nohup.out
drwxrw-rw-   3 diadras             diadras              4096 mrt  4 16:43 owncloud2
drwxrw----.  3 diadras             diadras              4096 mrt  4 16:43 owncloudbackup
drwxrwxr-x   3 diadras             diadras              4096 mei 26 16:57 ShoppingBuddy
drwxrwxr-x.  2 diadras             diadras              4096 mrt  4 12:02 VM1
Maarten
  • 234
Instead of messing with the config file, I prevented transmission-daemon from running automatically and opted, instead, to run it on demand. I created a new user called "fetch", with no shell, and made him a member of the plugdev group.
Then, from my own shell, I execute...
sudo -H -u fetch bash -c "transmission-daemon"
The config file is, or course, located in /home/fetch/.config
Unless you have something weird going on with your file system permissions, substituting debian-transmission for fetch should work to allow the process to write to the necessary directories.
Good luck to you.
