15
Is there a software which keeps time of my activities and gives a report? Based on focused window and window title. Report would just show time spent for specific window and its title like:
Application   Title                             Time
Firefox       Ask Ubuntu - Mozilla Firefox      5:58
Jacob Vlijm
  • 85,475
ambi
  • 193
EDIT: a version of the script with sorted reports can be found here
Always fun to write a script for it!
The script below will produce an output (report) like:
nautilus
0:00:05 (3%)
   0:00:05 (3%)     .usagelogs
firefox
0:01:10 (36%)
   0:00:05 (3%)     The Asker or the Answerer? - Ask Ubuntu Meta - Mozilla Firefox
   0:00:15 (8%)     scripts - Is there software which time- tracks window & application usage? - Ask Ubuntu - Mozilla Firefox
   0:00:10 (5%)     Ask Ubuntu - Mozilla Firefox
   0:00:15 (8%)     Why is a one line non-understandable answer used as review audit? - Ask Ubuntu Meta - Mozilla Firefox
   0:00:20 (10%)    bash - How to detect the number of opened terminals by the user - Ask Ubuntu - Mozilla Firefox
   0:00:05 (3%)     BlueGriffon - Mozilla Firefox
gedit
0:02:00 (62%)
   0:02:00 (62%)    2016_06_04_10_33_29.txt (~/.usagelogs) - gedit
started: 2016-06-04 10:33:29    updated: 2016-06-04 10:36:46
..which is updated once per minute.
Notes
  • The report will possibly report windows under the category: "Unknown". This is the case when windows have pid 0 (tkinter windows, such as Idle windows, aPython IDE). Their window title and usage will be reported correctly however.
  • The lock screen with password input is reported a "nux input window".
  • The percentages are rounded percentages, which might occasionally lead to minor differences between the application's percentage and the sum of its window's percentage.
    An example: If an application has two windows used, each used 0,7% of the total time, both windows will report 1% each (0.7 --> rounded to 1), while the application's usage reports 1% (1.4 --> rounded to 1)
    No need to say that these differences are totally irrelevant in the whole picture.
The script
#!/usr/bin/env python3
import subprocess
import time
import os
# -- set update/round time (seconds)
period = 5
# don change anything below
home = os.environ["HOME"]
logdir = home+"/.usagelogs"
def currtime(tformat=None):
    return time.strftime("%Y_%m_%d_%H_%M_%S") if tformat == "file"\
           else time.strftime("%Y-%m-%d %H:%M:%S")
try:
    os.mkdir(logdir)
except FileExistsError:
    pass
# path to your logfile
log = logdir+"/"+currtime("file")+".txt"; startt = currtime()
def get(command):
    try:
        return subprocess.check_output(command).decode("utf-8").strip()
    except subprocess.CalledProcessError:
        pass
def time_format(s):
    # convert time format from seconds to h:m:s
    m, s = divmod(s, 60); h, m = divmod(m, 60)
    return "%d:%02d:%02d" % (h, m, s)
def summarize():
    with open(log, "wt" ) as report:
        totaltime = sum([it[2] for it in winlist])
        report.write("")
        for app in applist:
            wins = [r for r in winlist if r[0] == app]
            apptime = sum([it[2] for it in winlist if it[0] == app])
            appperc = round(100*apptime/totaltime)
            report.write(("-"*60)+"\n"+app+"\n"+time_format(apptime)+\
                         " ("+str(appperc)+"%)\n"+("-"*60)+"\n")
            for w in wins:
                wperc = str(round(100*w[2]/totaltime))
                report.write("   "+time_format(w[2])+" ("+\
                             wperc+"%)"+(6-len(wperc))*" "+w[1]+"\n")
        report.write("\n"+"="*60+"\nstarted: "+startt+"\t"+\
                     "updated: "+currtime()+"\n"+"="*60)
t = 0; applist = []; winlist = []
while True:
    time.sleep(period)
    frpid = get(["xdotool", "getactivewindow", "getwindowpid"])
    frname = get(["xdotool", "getactivewindow", "getwindowname"])
    app = get(["ps", "-p", frpid, "-o", "comm="]) if frpid != None else "Unknown"
    # fix a few names
    if "gnome-terminal" in app:
        app = "gnome-terminal"
    elif app == "soffice.bin":
        app = "libreoffice"
    # add app to list
    if not app in applist:
        applist.append(app)
    checklist = [item[1] for item in winlist]
    if not frname in checklist:
        winlist.append([app, frname, 1*period])
    else:
        winlist[checklist.index(frname)][
            2] = winlist[checklist.index(frname)][2]+1*period
    if t == 60/period:
        summarize()
        t = 0
    else:
        t += 1
How to set up
  1. The script needs xdotool to get the window's information
    sudo apt-get install xdotool
  2. Copy the script into an empty file, save it as window_logs.py
  3. Test- run the script: tart the script by the command (from a terminal):
    python3 /path/to/window_logs.py
    After one minute, the script creates a log file with the first results in ~/.usagelogs. The file is time- stamped with the creation date & time. The file is updated once per minute.
    At the bottom of the file, you can see both the start- time and the time-stamp of the latest edit. This way you can always see what is the file's time span.
    If the script restarts, a new file with a new (start-) time stamp is created.
  4. If all works fine, add to Startup Applications: Dash > Startup Applications > Add. Add the command:
    /bin/bash -c "sleep 15 && python3 /path/to/window_logs.py"
More notes
  • ~/.uselogs is a hidden directory by default. Press (in nautilus) Ctrl+H to make it visible.
  • As it is, the script rounds the window's activeness on 5 seconds, assuming less then 5 seconds is not really using the window. If you'd like to change the value, set it in the head of the script in the line:
    period = 5
  • The script is extremely "low on juice". Furthermore, since the time- updates per window are done inside the script, the number of lines in the log file is limited to the actual number of used windows.
    Nevertheless, I wouldn't run the script for weeks in a row for example, to prevent accumulating too many lines (=window records) to maintain.
Jacob Vlijm
  • 85,475
there is arbtt that does exactly what you describe: https://www.joachim-breitner.de/blog/336-The_Automatic_Rule-Based_Time_Tracker
update: this project is still alive (Oct 2020) and the arbtt home page here: http://arbtt.nomeata.de/
the github project is here: https://github.com/nomeata/arbtt
mnagel
  • 995
Here's an even simpler script written in bash based on the xdotool mentioned in Jacob Vlijm's answer.
while :
do
    sleep 1
    echo $(date +"%H:%M:%S") $(xdotool getactivewindow getwindowname) >> $datapath/log-$(date +"%Y-%m-%d").txt;
done
Make sure to specify what $datapath is. Save the file as scrip.sh and run it in the background:
./script.sh &
Kill it in your jobs list to stop it. Or bring it to the foreground with fg and use ctrl-c.
If you prefer to sample at a rate slower than 1 second, change the sleep line. It saves data for each day in a separate file. Assuming 300 bytes per line, sampling at this rate will generate approximately 3600*24*300 = 25MB of data a day. That can be easily compressed (in post processing) as many window titles are repeated.
If you want usage percentages, awk the second column and pipe it to uniq -c and then pipe to sort -nr. That will give you the total number of minutes.
abnry
  • 101
