This error occurs when I install the apache2 & php5 around the time that libapace2-mod-php5 is installed:
root@ubuntuServerASC:/home/asc# apt-get install libapache2-mod-php5
Reading package lists... Done
Building dependency tree
cron : PreDepends: dpkg (>= 1.15.7.2)
Depends: adduser but it is not going to be installed
Depends: libpam-runtime (>= 1.0.1-11) but it is not going to be installed
init-system-helpers : Depends: perl-base (>= 5.20.1-3) but it is not going to be installed
libapache2-mod-php5 : Depends: libssl1.0.0 (>= 1.0.0) but it is not going to be installed
Depends: apache2-api-20120211
Depends: apache2 (>= 2.4) but it is not going to be installed
Depends: php5-common (= 5.5.9+dfsg-1ubuntu4.17) but it is not going to be installed
Depends: ucf but it is not going to be installed
Depends: tzdata but it is not going to be installed
Recommends: php5-cli but it is not going to be installed
libpam-modules : PreDepends: debconf (>= 0.5) but it is not going to be installed or
debconf-2.0
PreDepends: libpam-modules-bin (= 1.1.8-3.2ubuntu2)
Recommends: update-motd but it is not going to be installed
libpam0g : Depends: debconf (>= 0.5) but it is not going to be installed or
debconf-2.0
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
I tried use apt-cache to resolve the dependency but it didn't work.
root@ubuntuServerASC:/home/asc# apt-cache depends libapache2-mod-php5
libapache2-mod-php5
Depends: libbz2-1.0
Depends: libc6
Depends: libdb5.3
Depends: libpcre3
Depends: libxml2
Depends: zlib1g
Depends: <apache2-api-20120211>
apache2-bin
Depends: apache2
Depends: mime-support
Depends: libmagic1
Depends: ucf
Depends: tzdata
Conflicts: <libapache2-mod-php4>
Conflicts: libapache2-mod-php5filter
Suggests: php-pear
I installed all of the required packages.
I'm running ubuntu 16 LTS server.
