15
I am trying to install open edx with ubunty 16.04 and I get this error
There was an error while executing `VBoxManage`, a CLI used by Vagrant
for controlling VirtualBox. The command and stderr is shown below.
Command: ["startvm", "c60f0594-d584-4e0b-b863-2801168e641e", "--type", "headless"]
Stderr: VBoxManage: error: VT-x is not available (VERR_VMX_NO_VMX)
VBoxManage: error: Details: code NS_ERROR_FAILURE (0x80004005), component ConsoleWrap, interface IConsole
this occurs when using vagrant up
This is typically because you don't have VT-x or AMD-V enabled in your BIOS. Or worse yet, your CPU doesn't support virtualization.
You can test further by installing cpu-checker.
sudo apt-get install cpu-checker
Follow that with.
sudo kvm-ok
The output should be able to tell you what you need.
Keep in mind, vt-x can't be nested, so for instance, say you're trying to run vagrant on a cloud instance, in my experience that wont work. Atleast, for a 64 bit OS. You'll be able to run 32bit, however, that would be a single core and horrible performance.
This answer would be helpful for those running Windows and have Ubuntu installed through a Virtual Machine.
I faced this same error recently.
To specifically sort the error:
You need to:
  1. open the VM that has Ubuntu
  2. go to settings
  3. double click on Processors
  4. under Virtualization engine, check Virtualize Intel VT-x/EPT
  5. save the new settings.
Restart the VM and in your terminal for Ubuntu, go to the virtual environment that you were at. To view virtual environments run:
lsvirtualenv
And then run:
workon <name of virtual env>
After that, you can run the command:
vmcloak init --verbose --win7x64 win7x64base --cpus 2 --ramsize 2048
That should fix the issue.
moo
  • 966
