22
I try to install the Virtualbox software following the directions from the Oracle's website: https://www.virtualbox.org/wiki/Linux_Downloads
When I start Virtualbox is displayed to me the following message:
The vboxdrv kernel module is not loaded. Either there is no module available for the current kernel (4.4.0-22-generic) or it failed to load. Please recompile the kernel module and install it by: sudo /sbin/rcvboxdrv setup.
Additionally,I execute the directions from this answer: Can't install Virtualbox on 15.04
but my problem is not solved. Any ideas?
Panagiotis
  • 501
I don't think I had to do any of that on Ubuntu > 16.04. I would try the version in Ubuntu repositories. Simply install it from the Ubuntu Software or run the command:
sudo apt-get install virtualbox
You might want to undo any changes to the software sources.list that you have done first.
Katu
  • 3,663
Remove older version of virutalbox if it's installed in the system
sudo apt remove virtualbox
Add PPA to sources.list
sudo nano /etc/apt/sources.list
Add this file to the end of the file and do Ctrl+X to exit nano
deb http://download.virtualbox.org/virtualbox/debian xenial contrib
Fetch the GPG key
wget -q https://www.virtualbox.org/download/oracle_vbox_2016.asc -O- | sudo apt-key add -
Install the package
sudo apt update
sudo apt install virtualbox-5.1
Abhi
  • 31
