I am trying to clone old windows 8 HDD disk to new SSD. Both have the same capacity: 250GB
The problem is that dd command stops quickly after copying 10MB only.
Here is the output:
root@x72j:~# dd if=/dev/sdd of=/dev/sdc bs=128M conv=notrunc,noerror
0+1 records in
0+1 records out
10485760 bytes (10 MB) copied, 0.384963 s, 27.2 MB/s
I even tried copying to /dev/null
root@x72j:~# dd if=/dev/sdd of=/dev/null bs=128M conv=notrunc,noerror
0+1 records in
0+1 records out
10485760 bytes (10 MB) copied, 0.00766644 s, 1.4 GB/s
Why it doesn't clone full disk?
redochka
  • 171
For anyone experiencing the same issue, it is likely because you have actually created the "file" /dev/sdd
The virtual /dev parition is usually 10MB which is why the dd stops after 10MB.
Even if the "device" /dev/sdd later shows up, it will be blocked by the existing file.
Try ls -la /dev/sd* and you should see some anomalies.
Most dd commands can be replaced with cat.
E.g.:
cat /dev/sdd > /dev/sdc
Owl
  • 634
Try this:
exec sudo -i
fdisk -l
umount /dev/sdd?
fsck -y /dev/sdd?
dd if=/dev/sdd of=/dev/sdc bs=1M conv=noerror,sync
Change ? for the corresponding partition of /dev/sdd
kyodake
  • 17,808
