I'm installing nvidia-prime and select nvidia by the default. (I have proprietary nvidia-361). Then when i trying to launch Steam i'm getting those errors:
$ steam
Running Steam on ubuntu 16.04 64-bit
STEAM_RUNTIME is enabled automatically
[2016-05-28 19:45:46] Startup - updater built Apr 29 2016 22:18:33
SteamUpdateUI: An X Error occurred
X Error of failed request:  BadValue (integer parameter out of range for operation)
and that's it in here. Let's go there:
$ ./steam.sh
grep: symbol lookup error: grep: undefined symbol: pcre_jit_stack_alloc
[2016-05-28 19:50:48] Startup - updater built Apr 29 2016 22:18:33
Installing breakpad exception handler for appid(steam)/version(1461972496)
libGL error: unable to load driver: swrast_dri.so
libGL error: failed to load driver: swrast
My Steam installed in /home/$USER/.steam and i just run him by the ./steam.sh
From these Problem with installing Steam on Ubuntu 15.04+ only work that:
LD_LIBRARY_PATH="$LD_LIBRARY_PATH:/usr/lib32/nvidia-361/:/usr/lib/nvidia-361/" steam
But! When i just switch graphic to Intel (prime-select intel, and relog) i can easy run Steam from a command on a Desktop. The command is simple:
/home/$USER/.steam/steam.sh %U
But! I need run it like that only when i'm activate the Nvidia.
So, how i can create a new command on a desktop and run steam on nvidia without a terminal?
Paste this:
[Desktop Entry]
Name=Steam with NVidia
Exec=LD_LIBRARY_PATH="$LD_LIBRARY_PATH:/usr/lib32/nvidia-361/:/usr/lib/nvidia-361/" steam
Terminal=false
Icon=steam
Type=Application
Categories=Game;
...into a file called steamnvidia.desktop and put it in the directory /usr/local/share/applications. You should see other .desktop files in there that will have a similar structure to this. Make sure this file is executable (chmod +x steamnvidia.desktop), and you will probably need root powers to get it into the folder above.
Now search in dash (may take a couple times searching for it to reindex) "Steam with NVidia", as the Name= line in the file shows.
If you have to change the execution line for whatever reason, change the Exec= line to what you need.
You might also need to give the full steam path, not sure if environmental variables will work in desktop files.
