My current Situation:
  • my pc is running Xubuntu 16.04
  • a java jar app on Xubunutu desktop
  • a USB thermal printer (Model: DigiPOS 920) is connected via USB to my pc
  • the java app talks to the thermal printer via Java-POS and not via CUPS
My Question:
I am able to print but only if I have started my app via the terminal as su. If I just double click the jar file, I can start the app but it won't find the printer, thus no printing. Guys 'n Girls, please gimme a hint about:
How can I start the java jar App without the need for sudo? Or is there even a better approach for this case?
Chiggiddi
  • 345
You have 4 options from least secure to most secure:
  1. Run java as root by:
    a. Marking java as setuid root. OR
    b. Using sudo to say that the app can be run as root without a password. See NOPASSWD option in /etc/sudoers; or
  2. Give all users access to the USB device mentioned:
    a. By marking the device as read-write by everyone; or
    b. By marking the device as setuid root.
It depends how the app is accessing the device as to which option will work. I recommend trying option 2a first and working your way up the list.
Note that when marking anything as setuid root, you have to find the actual binary /usr/lib/java-....-/bin/java. setuid-root-ing the "alternatives" symlink is not going to work.
  1. Add your user to dialout group as this group has permission to read/write serial devices tty* or serial*.
    sudo usermod -a -G dialout $USER
    Reference: How do i allow non-root access to /ttyUSB0 on 12.04?
    If it has parallel port interface lp* (as the current case with DigiPOS 920) add your user to lp group.
    sudo usermod -a -G lp $USER
  2. Logout/Login
Further instructions: If it didn't work continue with the steps below
  1. Run watch lsusb, plug & unplug the printer, edit the question and add the printer info line as it shown in the output.
  2. Run
    watch "find /dev/ -iregex '.*lp.*' -printf '%p '; find /dev/ -iregex '.*tty.*' -printf '%p '"
    Plug & unplug the printer, edit the question and add the device node that created when you plug printer.
  3. Add output of:
    ls -l /dev/...
    udevadm info /dev/...
    udevadm info -a /dev/...
  4. Quick test, change permission
    sudo chmod +rw /dev/tty...
    Try your program without sudo, does it work?
  5. Now, we should add a udev rule to make that permanent.
user.dz
  • 49,176
