Quickbar is not allowed to configure. Just appears "..." and if I click on right button nothing happens. So it's not allowed external filters/commands and outputs resources because main menu is invisible.
I've got this output running it by user terminal:
(bluefish:3034): GLib-GObject-WARNING **: /build/buildd/glib2.0-2.40.2/./gobject/gsignal.c:2462: signal 'expose-event' is invalid for instance '0xedf390' of type 'GtkWindow'
cleanup_scanner, memory scancache 0(0Kb+0Kb) found 0(0Kb) fcontext 0(0Kb) = 0Kb
When I've tried to access bluefish under root terminal, main menu appears and the external filters/commands and outputs resources are available but the quickbar remains not responding. console output:
error reading list 1 Erro ao abrir arquivo: Arquivo ou diretório não encontrado
** (bluefish:3487): WARNING **: no configfile rcfile-2.0, try to convert config files from older versions
config file migration error 1:Erro ao abrir arquivo: Arquivo ou diretório não encontradoerror reading list 1 Erro ao abrir arquivo: Arquivo ou diretório não encontrado
I'm under ubuntu 14.04 LTS and it's updated. My bluefish version is 2.2.5-1.
The problem was caused by bluefish, any ubuntu component, or both?
gwarah
  • 283
