I just installed the new ubuntu 16.04 from 15.10, where I had set up a printer LBP6020. I'm following this guide
I found same steps across the net, so I guess it is quite common. Anyway, when I upgraded to 16.04 tried to install it again using same steps, no success or whatsoever. When I issue a command /etc/init.d/ccpd status I get not two not one but like 5 rows of numbers, maybe about 50-70.
Otherwise, accessing the printer from the cups web based interface, I can see it and I can assign it a task to print a test page, although it shows job completed I don't see anything.
CUPS_ConfigPath = /etc/cups/
LOG Path        = None
UI Port         = 59787
Entry Num  : Spooler    : Backend   : FIFO path     : Device Path   :   Status
 [0]    : LBP6020   : ccp       : //localhost:59687     : /dev/usb/lp0  : New! !
Don't know what the issue is, maybe have to wait for new drivers?
muru
  • 207,228
Nick
  • 263
I've done some digging on this issue. I have found a way on how to get the Canon LBP6020 printer working.
My Ubuntu version is 16.04 64-Bit with the Canon CAPT Printer Driver Version 2.70.
Firstly I had to setup Ubuntu so it could install 32-bit packages. Even though we're installing 64 Bit Canon drivers, some parts of the installation will need 32-bit packages installing. To get this setup I followed the instructions here: Installing 32-bit libraries on Ubuntu 14.04 LTS 64-bit, running the code:
sudo dpkg --add-architecture i386
sudo apt-get update
sudo apt-get install libc6:i386 libncurses5:i386 libstdc++6:i386 libpopt0:i386
Then for installing the Canon packages, I followed these instructions from the French Ubuntu docs: https://doc.ubuntu-fr.org/imprimante_canon_capt2, please take note of the parts where the instructions mention installing the libglade2-0 package and these 32-bit packages: libatk1.0-0:i386,libcairo2:i386,libgtk2.0-0:i386,libpango1.0-0:i386,libstdc++6:i386,libxml2:i386,libpopt0:i386. You will also have to update the /etc/init.d/ccpd file with what is mentioned in the instructions.
I won't re-post the instructions here as the page linked above includes all of the instructions I used for my setup to work properly, hopefully this will work for you too.
Another issue I ran into, was when running Google translate on the French instructions, Google translate changed some of the text within the commands. It's best if you can install any commands from the original non-translated version (I kept the translated and non-translated pages side-by-side).
Cheers, hope this helps.
GuySoft
  • 784
I tried all the other answers but none worked for me. This was the only way it worked in my case (Xubuntu 17.04):
Download a script canon_lbp_setup.sh from russian community;
cd ~/Downloads
chmod +x canon_lbp_setup.sh
sudo apt-get update
./canon_lbp_setup.sh
There could be errors about dependencies; if so, run
sudo apt-get install -f
The only dependency that was not found in our repos was libpng12-0, I found it here, downloaded the .deb package and installed it using:
sudo dpkg -i libpng12-0_1.2.54-1ubuntu1_amd64.deb
Every time you execute sudo apt-get install -f to install some dependency you have to run the script ./canon_lbp_setup.sh again.
Zanna
  • 72,312
