I built a computer recently and want to install Kubuntu 16.04 onto it. I have downloaded the 64-bit ISO, checked the MD5 sum, and burned it as an ISO image. The computer recognizes the DVD and loads it, and the DVD will begin to boot, except while the system is starting services it locks up (it doesn't always lock up on the same service, though). There is no activity on the DVD drive, and I can't interact with the computer anymore. It just sits there until the computer is reset or turned off. I have tried this also with Kubuntu 14.04 and Mythbuntu 12.04.1, and they all lock up while trying to start services. All of these installation disks have successfully booted in other computers I have.
The motherboard does have UEFI enabled, and I have turned off Secure Boot and Fast Boot. Not that it matters, though, I tried booting it in legacy mode and the same exact thing happened...
I have also tried to add the following kernel parameters:
nomodesetandnouveau.modeset=0: Graphics appeared to work fine without but just to check I used this anyway. No luck.noninteractiveinstead ofmaybe-ubiquityto keep it from launching an X server, but still locks upacpi=offbut then the disc just doesn't boot at all
I have been able to boot openSUSE and Windows 10 installation media on the computer, so it appears to be an Ubuntu problem.
Here are some of the system specs, if it matters:
- CPU: AMD FX-8320E
- Motherboard: ASUS 970 Pro Gaming/Aura
- GPU: GeForce 210
- It also has a Hauppage HVR-1600 installed
