18
Ubuntu 16.04 64 bit taking around 20 sec from Login screen to desktop and around 20 seconds from grub to login screen,
tell me which services i can safely disable, i do not use virtualbox and bluetooth frequently, all other things are used like printer, wifi etc.
output of systemd-analyze
Startup finished in 5.145s (kernel) + 14.138s (userspace) = 19.284s
and output of
systemd-analyze blame
 5.837s accounts-daemon.service
          5.444s dev-sda6.device
          4.864s grub-common.service
          4.105s lightdm.service
          4.075s ModemManager.service
          4.001s preload.service
          3.844s apparmor.service
          3.566s networking.service
          3.468s apport.service
          3.332s ondemand.service
          3.272s rsyslog.service
          3.269s systemd-logind.service
          3.253s alsa-restore.service
          3.241s gpu-manager.service
          3.226s avahi-daemon.service
          3.185s systemd-user-sessions.service
          3.185s pppd-dns.service
          2.508s NetworkManager.service
          2.003s user@1000.service
          1.640s plymouth-quit-wait.service
          1.245s colord.service
           712ms systemd-update-utmp.service
           687ms systemd-udevd.service
           669ms udisks2.service
           632ms polkitd.service
           602ms brltty.service
           572ms systemd-localed.service
           567ms systemd-backlight@backlight:intel_backlight.service
           543ms systemd-rfkill.service
           527ms systemd-tmpfiles-setup-dev.service
           519ms thermald.service
           490ms systemd-tmpfiles-setup.service
           464ms systemd-modules-load.service
           454ms systemd-tmpfiles-clean.service
           450ms systemd-timesyncd.service
           428ms systemd-journald.service
           371ms wpa_supplicant.service
           340ms ufw.service
           317ms systemd-random-seed.service
           284ms console-setup.service
           281ms plymouth-start.service
           270ms dev-hugepages.mount
           270ms sys-kernel-debug.mount
           224ms systemd-udev-trigger.service
           177ms dev-mqueue.mount
           168ms plymouth-read-write.service
           165ms upower.service
           131ms dns-clean.service
           103ms systemd-sysctl.service
           102ms dev-disk-by\x2duuid-8bd6db03\x2da87b\x2d4614\x2d927a\x2dd5916f3
            68ms systemd-hostnamed.service
            49ms systemd-journal-flush.service
            47ms kmod-static-nodes.service
            47ms snapd.socket
            32ms systemd-remount-fs.service
            28ms rc-local.service
            10ms resolvconf.service
            10ms rtkit-daemon.service
             9ms systemd-update-utmp-runlevel.service
             6ms ureadahead-stop.service
             4ms sys-fs-fuse-connections.mount lines 39-61/61 (END)
As well as:
systemd-analyze critical-chain
the time after the unit is active or started is printed after the "@" character.
The time the unit takes to start is printed after the "+" character.
graphical.target @14.124s
└─lightdm.service @10.018s +4.105s
  └─systemd-user-sessions.service @6.731s +3.185s
    └─basic.target @6.625s
      └─sockets.target @6.625s
        └─snapd.socket @6.576s +47ms
          └─sysinit.target @6.574s
            └─swap.target @6.574s
              └─dev-disk-by\x2duuid-8bd6db03\x2da87b\x2d4614\x2d927a\x2dd5916f3c
lines 1-13/13 (END)
i am using a HDD with 7200 RPM, i think boot time is okay, but after login screen, i have to pass 20 secs with a blank screen, I have already disabled some startup items like ORCA, BLUETOOTH, backup monitor, accessibility etc, personal file sharing and user folder update etc, still nothing is improving, how to diagnose the culprit and treat it.
nixpower
  • 1,230
  • 19
Kanhiya
  • 439
Try removing some unused dependencies and orphan packages. This will help.
It worked in my case. Run:
sudo apt autoremove && sudo apt autoclean
Also, you can install Gtkorphan (sudo apt-get install gtkorphan) to remove all orphaned packages and dependencies left behind by other apps.
Eric Carvalho
  • 55,453
Collin
  • 601
