10
In one of the labs for learning Linux system administrator I have to do :
  1. Now change the value by modifying /etc/sysctl.conf and force the system to activate this setting file without a reboot.
  2. Check that this worked properly.
here is what i must do:
Add the following line to /etc/sysctl.conf:
net.ipv4.icmp_echo_ignore_all=1
and then do:
$ sysctl -p
how to do this and with which text editor?
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Mokum
  • 355
1. You can add this line using nano or vim from terminal (ctrl+alt+t):
sudo nano /etc/sysctl.conf
where you then scroll down and add the line by hand then press ctrl+x to end editing. You will be asked if you want to save, confirm that by pressing y and then once return to save.
Same way you can reverse your changes.
2. You can add it as well this way:
echo "net.ipv4.icmp_echo_ignore_all=1" | sudo tee -a /etc/sysctl.conf
For reversing this refer to solution 1.
Videonauth
  • 33,815
