In order to fix a sound issue, I'd completely removed all PulseAudio packages, which removed several additional packages which I hadn't kept track of.
I have since added back several packages that had depended upon some of the packages, such as xubuntu-desktop (yes, I'm using Xubuntu, not the default Ubuntu setup).
Unfortunately, this has broken my setup a little bit, in that on boot, my graphical desktop manager is not started automatically. (in this case, I'm using GDM, not LightDM)
I can switch to a virtual terminal (via Alt-F1), login, then launch GDM with the following command:
sudo service gdm start
But this doesn't solve the problem itself.
I've also discovered that GDM is being started upon boot, but it's also getting killed by something.
Any help you guys can give would be great, because this is getting beyond annoying.
Jorge Castro
  • 73,717
Try this:
Ctrl+Alt+F1
sudo apt-get install -f -m --reinstall -u gdm
Meaning of the short options:
-f : fix broken
-m : fix missing
--reinstall : refresh archives to newest versions
Useful option:
-u : print out a list of all packages that are to be upgraded
Next:
sudo dpkg-reconfigure gdm
select GDM instead LightDM
Finally:
sudo reboot
Enjoy!
swift
  • 3,291
