I am mounting an iso file downloaded from CentOS website using below command as root
mount -t iso9660 -o loop /root/Centos7ISO/CentOS-7-x86_64-Everything-1511.iso /mnt/CentOS7/
But it throws this warning about a read-only device
mount: /dev/loop2 is write-protected, mounting read-only
I searched a lot and found several similar issues but none of the solutions worked in my case.
total 1490
-r--r--r--. 1 root root      14 Dec 10 06:35 CentOS_BuildTag
dr-xr-xr-x. 3 root root    2048 Dec 10 06:33 EFI
-r--r--r--. 1 root root     215 Dec 10 06:35 EULA
-r--r--r--. 1 root root   18009 Dec 10 06:35 GPL
dr-xr-xr-x. 3 root root    2048 Dec 10 06:33 images
dr-xr-xr-x. 2 root root    2048 Dec 10 06:33 isolinux
dr-xr-xr-x. 2 root root    2048 Dec 10 06:33 LiveOS
dr-xr-xr-x. 2 root root 1486848 Dec 10 06:34 Packages
dr-xr-xr-x. 2 root root    4096 Dec 10 06:35 repodata
-r--r--r--. 1 root root    1690 Dec 10 06:35 RPM-GPG-KEY-CentOS-7
-r--r--r--. 1 root root    1690 Dec 10 06:35 RPM-GPG-KEY-CentOS-Testing-7
I even tried to use chmod to grant full rw permission to files, but Chmod +777 also does not work since it is a read-only mount.
Zanna
  • 72,312
Espanta
  • 129
Iso's only do mount read-only. It's just the fact. I believe the reason is that ISO's have a specific structure that would have to be remade every time you unmounted the ISO which would take a ridiculous amount of processing power for limited functionality advantage.
anonymous2
  • 4,325
