I am regularly running a shell script through Crontab that uses SSH to connect to a server. If I run that script manually it runs through successfully. Within the same session Crontab will successfully run it, too. But if I restart my machine and wait for Crontab to start the script, then it fails.
My machine and the server I connect to both have keys without password of each other.
SSH-command in my script:
ssh -i /home/myuser/.ssh/id_rsa -t -t myuser@servername 'some-script-on-the-server'
Crontab-command:
45 10   * * *   root    sudo -u myuser my-local-script
I thought I'd solve this issue by providing the SSH command with -i /home/myuser/.ssh/id_rsa but this did it still did not work after that.
The output of /var/log/syslog is:
May 23 11:06:01 mycomputer CRON[1254]: (root) CMD (sudo -u myuser my-local-script)
May 23 11:06:01 mycomputer CRON[1252]: (CRON) info (No MTA installed, discarding output)
What's the problem?
Socrates
  • 2,645
"No MTA installed" means that in your script, you might want to send an email, but no MTA (Mail Transfer Agent) have been specified. The cron daemon tries in fact to send outputs to you. You can install an MTA (like postfix), or, if outputs are not important, redirect to" /dev/null 2>&1"
limace255
  • 151
