13
The PHP function bcdiv is not available by default. How do I enable that in PHP configuration?
muru
  • 207,228
  1. Install module bcmath
    sudo apt-get install php-bcmath
(note: on ubuntu 16.04^ with PHP 7.0^ use php7.0-bcmath package instead)
  1. Restart apache service eventually
    sudo service apache2 restart
11
Install module bcmath in PHP 7.0, you should try:
sudo apt-get install php7.0-bcmath
And restart php engine or apache
Kenny
  • 111
If you're using Docker, then you can install it using docker-php-ext-install:
# Dockerfile
FROM php:7.4-fpm-alpine
RUN docker-php-ext-install bcmath
Scofield
  • 121
