I have 2 external monitors connected to the docking station. I can only make 1 of them to work.
I am pretty sure that to drive the second monitor I will need to use the NVidia adapter.
It used to work while I was on the proprietary nvidia drivers. Had to switch no nouveau (Xephyr wouldn't support OpenGL with the proprietary drivers).
I can see in Xorg.0.log:
[ 4.367] (--) PCI:*(0:0:2:0) 8086:0416:1028:05cc rev 6, Mem @ 0xf5400000/4194304, 0xd0000000/268435456, I/O @ 0x0000f000/64
[ 4.367] (--) PCI: (0:1:0:0) 10de:0ff6:1028:15cc rev 161, Mem @ 0xf4000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
Xorg sees the nvidia adapter (PC: 1:0:0) but does not load the nouveau driver. How can I force it to do so?
Note: going back to the proprietary driver is not an option.
Hardware: Laptop Dell M4800 with a docking station
$ lspci | grep VGA
00:02.0 VGA compatible controller: Intel Corporation 4th Gen Core Processor Integrated Graphics Controller (rev 06)
01:00.0 VGA compatible controller: NVIDIA Corporation GK107GLM [Quadro K1100M] (rev a1)
dmesg: http://pastebin.com/9J0pq6tn
Xorg.0.log: http://pastebin.com/NWj5tsS6
xrandr command to align the 2 working monitors:
xrandr \
--output HDMI1 --off \
--output VIRTUAL1 --off \
--output DP1 --mode 1920x1080 --pos 1920x0 --rotate left
--output eDP1 --mode 1920x1080 --pos 0x760 --rotate normal --dpi 150/eDP1\
--output VGA1 --off
(eDP1 is the build-in monitor, DP1 is the external monitor)
xrandr command that used to work with the proprietary drivers:
xrandr \
--output DP1 --off \
--output eDP1 --mode 1920x1080 --pos 0x840 --rotate normal \
--output VGA1 --off \
--output DP-5 --off \
--output DP-4 --off \
--output DP-3 --mode 1920x1080 --pos 1920x0 --rotate left \
--output DP-2 --mode 1920x1080 --pos 3000x552 --rotate normal \
--output DP-1 --off \
--output DP-0 --off
Port DP-3 from the proprietary driver is now named DP1 (probably by the Intel driver?
Port DP-2 from the proprietary driver is the one I would like to use
$ xrandr -q
Screen 0: minimum 8 x 8, current 3000 x 1920, maximum 32767 x 32767
eDP1 connected 1920x1080+0+760 (normal left inverted right x axis y axis) 344mm x 194mm
1920x1080 60.04*+ 40.03 59.93
1680x1050 59.95 59.88
1600x1024 60.17
1400x1050 59.98
1600x900 60.00
1280x1024 60.02
1440x900 59.89
1280x960 60.00
1368x768 60.00
1360x768 59.80 59.96
1152x864 60.00
1280x720 60.00
1024x768 60.00
1024x576 60.00
960x540 60.00
800x600 60.32 56.25
864x486 60.00
640x480 59.94
720x405 60.00
640x360 60.00
DP1 connected 1080x1920+1920+0 left (normal left inverted right x axis y axis) 509mm x 286mm
1920x1080 60.00*+
1600x900 60.00
1280x1024 75.02 60.02
1152x864 75.00
1024x768 75.08 60.00
800x600 75.00 60.32
640x480 75.00 60.00
720x400 70.08
HDMI1 disconnected (normal left inverted right x axis y axis)
VGA1 disconnected (normal left inverted right x axis y axis)
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
HDMI1 and VGA1 are unusable (blocked by the docking station)
Tried to get rid of the docking station but had the same problem - the Intel driver alone would not drive 3 video outputs.
OS is Lubuntu 16.04 (upgraded from 15.10)
