I have a bridge created on my ubunut 16.04 box. The bridge does not get an IP from my DHCP server on the network on boot.
/etc/network/interfaces :
# interfaces(5) file used by ifup(8) and ifdown(8)
auto br0
iface br0 inet dhcp
    bridge-ifaces eno1
    bridge-ports eno1
    up ifconfig eno1 up
iface eno1 inet manual
auto lo
iface lo inet loopback
When the machine is booted, it has no connection to the LAN, there is no internet connection. The IP's on my lan are 192.168.11.xx. The IP of the bridge on boot is 10.255.212.1.
On boot:
bas@Viky:~$ ifconfig
br0       Link encap:Ethernet  HWaddr fc:aa:14:72:d0:af
          inet addr:10.255.212.1  Bcast:0.0.0.0  Mask:255.255.255.0
          inet6 addr: fe80::feaa:14ff:fe72:d0af/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:397 errors:0 dropped:0 overruns:0 frame:0
          TX packets:212 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:506043 (506.0 KB)  TX bytes:18913 (18.9 KB)
eno1      Link encap:Ethernet  HWaddr fc:aa:14:72:d0:af
          RX packets:1191 errors:0 dropped:4 overruns:0 frame:0
          TX packets:951 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:1285826 (1.2 MB)  TX bytes:108134 (108.1 KB)
          Interrupt:20 Memory:f7c00000-f7c20000
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:189 errors:0 dropped:0 overruns:0 frame:0
          TX packets:189 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:13790 (13.7 KB)  TX bytes:13790 (13.7 KB)
vethVOCFUV Link encap:Ethernet  HWaddr fe:4e:32:1f:b7:f4
          inet6 addr: fe80::fc4e:32ff:fe1f:b7f4/64 Scope:Link
          RX packets:743 errors:0 dropped:0 overruns:0 frame:0
          TX packets:793 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:85052 (85.0 KB)  TX bytes:776556 (776.5 KB)
After boot this can be corrected by ifdown -a and ifup -a.
bas@Viky:~$ sudo ifdown -a
[sudo] password for bas:
Killed old client process
Internet Systems Consortium DHCP Client 4.3.3
Copyright 2004-2015 Internet Systems Consortium.
All rights reserved.
For info, please visit https://www.isc.org/software/dhcp/
Listening on LPF/br0/fc:aa:14:72:d0:af
Sending on   LPF/br0/fc:aa:14:72:d0:af
Sending on   Socket/fallback
DHCPRELEASE on br0 to 192.168.11.1 port 67 (xid=0x79a7a104)
Get the network up:
bas@Viky:~$ sudo ifup -a
Waiting for br0 to get ready (MAXWAIT is 32 seconds).
DHCPDISCOVER on br0 to 255.255.255.255 port 67 interval 3 (xid=0x177d1021)
DHCPREQUEST of 192.168.11.28 on br0 to 255.255.255.255 port 67 (xid=0x21107d17)
DHCPOFFER of 192.168.11.28 from 192.168.11.1
DHCPACK of 192.168.11.28 from 192.168.11.1
bound to 192.168.11.28 -- renewal in 274608 seconds.
I don't understand why the bridge does not get an IP address from the DHCP server on boot.
Can anyone help met out with this please?
Where do I start on this networking challange?
Bas
(Because I did not get any response on this question, I figured it is to broad. Therefore made this sub question.)
I believe for your bridge section, it should look like:
It is bridge_ports not bridge-ports
auto br0
iface br0 inet dhcp
    bridge_ports eno1
    bridge_stp off
    bridge_fd 0
    bridge_maxwait 0
More information can be found here.
Example from my system:
$ cat /etc/network/interfaces
# The network interface
auto br0
iface br0 inet dhcp
   bridge_ports eth0
   bridge_stp off
   bridge_fd 0
   bridge_maxwait 0
iface eth0 inet manual
auto lo
$ ifconfig
br0       Link encap:Ethernet  HWaddr 00:21:85:94:46:a4
          inet addr:10.0.0.100  Bcast:10.0.0.255  Mask:255.255.255.0
          RX packets:195 errors:0 dropped:0 overruns:0 frame:0
          TX packets:211 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:39400 (39.4 KB)  TX bytes:27433 (27.4 KB)
eth0      Link encap:Ethernet  HWaddr 00:21:85:94:46:a4
          RX packets:278675 errors:0 dropped:0 overruns:0 frame:0
          TX packets:263759 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:110002223 (110.0 MB)  TX bytes:408874062 (408.8 MB)
          RX packets:64269 errors:0 dropped:0 overruns:0 frame:0
          TX packets:64269 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:23474196 (23.4 MB)  TX bytes:23474196 (23.4 MB)
Hope this helps!
Terrance
  • 43,712
