36
I have done the following:
sudo apt-get install vim-gnome
But I get the following:
vim-gnome : Depends: libruby1.8 (>= 1.8.7.352) but 1.8.6.111-2ubuntu1 is to be installed
I've done:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get dist-upgrade
Contents of my /etc/apt/sources.list file:
deb http://us.archive.ubuntu.com/ubuntu/ oneiric main restricted
deb-src http://us.archive.ubuntu.com/ubuntu/ oneiric main restricted
deb http://us.archive.ubuntu.com/ubuntu/ oneiric-updates main restricted
deb-src http://us.archive.ubuntu.com/ubuntu/ oneiric-updates main restricted
deb http://us.archive.ubuntu.com/ubuntu/ oneiric universe
deb-src http://us.archive.ubuntu.com/ubuntu/ oneiric universe
deb http://us.archive.ubuntu.com/ubuntu/ oneiric-updates universe
deb-src http://us.archive.ubuntu.com/ubuntu/ oneiric-updates universe
deb http://us.archive.ubuntu.com/ubuntu/ oneiric multiverse
deb-src http://us.archive.ubuntu.com/ubuntu/ oneiric multiverse
deb http://us.archive.ubuntu.com/ubuntu/ oneiric-updates multiverse
deb-src http://us.archive.ubuntu.com/ubuntu/ oneiric-updates multiverse
deb http://security.ubuntu.com/ubuntu oneiric-security main restricted
deb-src http://security.ubuntu.com/ubuntu oneiric-security main restricted
deb http://security.ubuntu.com/ubuntu oneiric-security universe
deb-src http://security.ubuntu.com/ubuntu oneiric-security universe
deb http://security.ubuntu.com/ubuntu oneiric-security multiverse
deb-src http://security.ubuntu.com/ubuntu oneiric-security multiverse
But all to no avail. I always get the same error above.
What can I do to resolve?
croceldon
  • 595
5 Answers5
39
On Ubuntu 20.04 (since vim-gnome was removed in 19.10):
sudo apt install vim-gtk3
muru
  • 207,228
Mudassir
  • 491
30
The following worked for me:
run this
sudo apt-get update
and then run
0x90
  • 543
You'll need to check your sources. I see that libruby1.8 1.8.7.352-2 is available through main while it seems that the newest version you have is: 1.8.6.111-2ubuntu1. This probably means that you dist-upgrade failed or that you still need to update your sources.
$ apt-cache policy libruby1.8
libruby1.8:
  Installed: 1.8.7.352-2
  Candidate: 1.8.7.352-2
  Version table:
 *** 1.8.7.352-2 0
        500 http://archive.ubuntu.com/ubuntu/ oneiric/main amd64 Packages
        100 /var/lib/dpkg/status
jcollado
  • 9,868
in Ubuntu 16.04 it should be:
sudo apt update
and then
sudo apt install vim-gnome
What worked for me :
sudo apt remove vim-common
Ravexina
  • 57,256
