So I am having a lot of difficulties with getting my TK1 board setup and ready for development.
I tried installing Chrome and I got an error related to "i386" when I tried to install it. I also tried installing Teamviewer and I also got the same error.
Now, whenever I try to run "sudo apt-get update" or anyhting similar, I get errors related to not able to get i386 package:
ubuntu@tegra-ubuntu:/var/lib/apt/lists$ sudo apt-get update
Ign http://ports.ubuntu.com trusty InRelease
Hit http://ports.ubuntu.com trusty-updates InRelease
Hit http://ports.ubuntu.com trusty-security InRelease
Hit http://ports.ubuntu.com trusty Release.gpg
Hit http://ports.ubuntu.com trusty-updates/main Sources
Hit http://ports.ubuntu.com trusty-updates/restricted Sources
Hit http://ports.ubuntu.com trusty-updates/main armhf Packages
Hit http://ports.ubuntu.com trusty-updates/restricted armhf Packages
Hit http://ports.ubuntu.com trusty-updates/main Translation-en
Hit http://ports.ubuntu.com trusty-updates/restricted Translation-en
Hit http://ports.ubuntu.com trusty-security/main Sources
Hit http://ports.ubuntu.com trusty-security/restricted Sources
Hit http://ports.ubuntu.com trusty-security/main armhf Packages
Hit http://ports.ubuntu.com trusty-security/restricted armhf Packages
Hit http://ports.ubuntu.com trusty-security/main Translation-en
Hit http://ports.ubuntu.com trusty-security/restricted Translation-en
Hit http://ports.ubuntu.com trusty/main Sources
Hit http://ports.ubuntu.com trusty/restricted Sources
Hit http://ports.ubuntu.com trusty/main armhf Packages
Hit http://ports.ubuntu.com trusty/restricted armhf Packages
Hit http://ports.ubuntu.com trusty/main Translation-en
Hit http://ports.ubuntu.com trusty/restricted Translation-en
Err http://ports.ubuntu.com trusty-updates/main i386 Packages
  404  Not Found [IP: 2001:67c:1360:8001:1::2 80]
Err http://ports.ubuntu.com trusty-updates/restricted i386 Packages
Err http://ports.ubuntu.com trusty-security/main i386 Packages
Err http://ports.ubuntu.com trusty-security/restricted i386 Packages
Err http://ports.ubuntu.com trusty/main i386 Packages
Err http://ports.ubuntu.com trusty/restricted i386 Packages
Ign http://ports.ubuntu.com trusty/main Translation-en_US
Ign http://ports.ubuntu.com trusty/restricted Translation-en_US
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/trusty-updates/main/binary-i386/Packages  404  Not Found [IP: 2001:67c:1360:8001:1::2 80]
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/trusty-updates/restricted/binary-i386/Packages  404  Not Found [IP: 2001:67c:1360:8001:1::2 80]
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/trusty-security/main/binary-i386/Packages  404  Not Found [IP: 2001:67c:1360:8001:1::2 80]
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/trusty-security/restricted/binary-i386/Packages  404  Not Found [IP: 2001:67c:1360:8001:1::2 80]
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/trusty/main/binary-i386/Packages  404  Not Found [IP: 2001:67c:1360:8001:1::2 80]
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/trusty/restricted/binary-i386/Packages  404  Not Found [IP: 2001:67c:1360:8001:1::2 80]
This is what is in my /etc/apt/sources.list:
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://ports.ubuntu.com/ubuntu-ports/ trusty main restricted
deb-src http://ports.ubuntu.com/ubuntu-ports/ trusty main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://ports.ubuntu.com/ubuntu-ports/ trusty-updates main restricted
deb-src http://ports.ubuntu.com/ubuntu-ports/ trusty-updates main restricted
## Uncomment the following two lines to add software from the 'universe'
## repository.
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team. Also, please note that software in universe WILL NOT receive any
## review or updates from the Ubuntu security team.
# deb http://ports.ubuntu.com/ubuntu-ports/ trusty universe
# deb-src http://ports.ubuntu.com/ubuntu-ports/ trusty universe
# deb http://ports.ubuntu.com/ubuntu-ports/ trusty-updates universe
# deb-src http://ports.ubuntu.com/ubuntu-ports/ trusty-updates universe
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
# deb http://ports.ubuntu.com/ubuntu-ports/ trusty-backports main restricted
# deb-src http://ports.ubuntu.com/ubuntu-ports/ trusty-backports main restricted
deb http://ports.ubuntu.com/ubuntu-ports/ trusty-security main restricted
deb-src http://ports.ubuntu.com/ubuntu-ports/ trusty-security main restricted
# deb http://ports.ubuntu.com/ubuntu-ports/ trusty-security universe
# deb-src http://ports.ubuntu.com/ubuntu-ports/ trusty-security universe
# deb http://ports.ubuntu.com/ubuntu-ports/ trusty-security multiverse
# deb-src http://ports.ubuntu.com/ubuntu-ports/ trusty-security multiverse
I tried cleaning stuff using "sudo apt-get clean" and "sudo apt-get autoclean", etc.. but to no good. I am not sure why after downloading and trying to install chrome or teamviewer, I would get this error.
I would appreciate any help with this...
So after a good night of sleep, I decided to google the issue with a failed "sudo apt-get update" and I found that the following thing fixed my issue:
ubuntu@tegra-ubuntu:~$ dpkg --print-foreign-architectures
i386
ubuntu@tegra-ubuntu:~$ sudo dpkg --remove-architecture i386
Apparently, I had added a foreign architecture "i386" and that was causing all the issues and I am not sure why I didn't see this before.
There you go, I hope this helps someone else.
This is the link that helped me try this approach. It's not exactly the same issue, but the solution is the same: Apt-get update fails ubuntu 14.04
