Context: Meizu PRO 5 w/ UbuntuTouch OTA-10.2 (unboxed today). Developer Mode, and a rw filesystem.
Question, qml and qmlscene segfault, and have broken symlinks:
phablet@ubuntu-phablet:~$ qmlscene
Loading module: 'libubuntu_application_api_touch_mirclient.so.3.0.0'
UbuntuClientIntegration: connection to Mir server failed. Check that a Mir server is
running, and the correct socket is being used and is accessible. The shell may have
rejected the incoming connection, so check its log file
Aborted
phablet@ubuntu-phablet:~$ export MIR_SOCKET=/var/run/mir_socket
Segmentation fault
qml: could not exec '/usr/lib/arm-linux-gnueabihf/qt5/bin/qml': No such file or directory
Note, MIR_SOCKET seems to not be set by default.
One last thing: there should be a StackExchange tag for OTA-10 (etc)
paul_h
  • 121
You cannot run qmlscene from the terminal like that. Applications are run under confinement.
Also, you should not set the device root filesystem to read/write mode. It will only result in problems with updates in the future.
dobey
  • 41,650
