-1
First off all, i am a novice of Linux so ignore any mistakes in my question.
I have installed Ubuntu 16.04 on my Windows-10 laptop. I want to use both of them on the same machine. When ever I start the computer it is directly going to Windows login. I have to go to boot options of HP and have to select Ubuntu partition to login to Ubuntu.
I want to enable a menu option while startup which will ask which OS to boot and login.
Thanks in advance
this is what i did on my laptop with pre-installed w8 (upgraded to w10)
step 1: download the live cd
step 2: boot into environment (aka try it first)
step 3: install through the environment
step 4: select install next to windows
step 5: do not reboot the computer when the installation is done
step 6: open a terminal in the live environment and do the following
terminal step 1 (calling it tstep now): type sudo su
tstep 2: apt-get install efibootmgr
tstep 3: efibootmgr
and then make sure that ubuntu is first boot, you might need to edit that in your BIOS, after that you are good to go :)
patrick
  • 573
