the full question is: The 'mail name' is the domain name used to 'qualify' mail addresses without a domain name.
This name will also be used by other programs. It should be the single,
fully qualified domain name (FQDN).
Thus, if a mail address on the local host is foo@example.org, the
correct value for this option would be example.org
then it tells me to enter it. this error came up while i was installing some required packages for Hamachi that it wouldn't install. thank you for any help.
jaw2233
  • 173
The application is asking for your domain name for emailing. If you have a domain that you are on, you would just type that in like:
example.com
But if you don't have a domain that you are part of, the hostname of your computer would be the domain name. To get your hostname, it is either the name right after the @ in the terminal prompt, or you type in hostname from the prompt to get your hostname:
terrance@terrance-ubuntu:~$
terrance@terrance-ubuntu:~$ hostname
terrance-ubuntu
Hope this helps!
Terrance
  • 43,712
