I have a dell inspiron computer. I installed Ubuntu 11.10. I don't want to use its touchpad but I could not disable it. gconf-editor cannot be useful because touchpad is not seen in peripherals although it is properly working.
What should I do?
My hardware: Alps Touchpad for Inspiron N5110
Bruno Pereira
  • 74,715
adba
  • 125
sudo add-apt-repository ppa:atareao/atareao
sudo apt-get update
sudo apt-get install touchpad-indicator
This didn't work for me until I unplugged and plugged my mouse back in... -12.04Beta
Works great now though!
BDBunes
sudo apt-get update
After installation, open the indicator from Applications -> Accessories -> Touchpad Indicator and set your touchpad in top-right
This is the easiest way to disable.
twister_void
  • 5,934
If the touchpad is still not working, go in bios menu and search touchpad and change the TP from Advanced to Basic. that was my experience to run my touchpad.
Elder Geek
  • 36,752
touchpad-indicator didn't work for me, so I wrote a little script to do it instead, and bound it to a shortcut key (Ctrl-F1).
it's a wee Python script, only a dozen lines, just sharing it in case anyone else finds it useful:
grab the code from: https://gist.github.com/1336648
save as /usr/local/bin/toggle_touchpad.py, eg by opening
gksudo gedit /usr/local/bin/toggle_touchpad.py
and pasting the code in.
then, sudo chmod +x /usr/local/bin/toggle_touchpad.py
then, go to settings-->keyboard-->shortcuts-->custom shortcuts add a new shortcut, call it eg toggle touchpad on/off, and give the command as toggle_touchpad.py.
Click OK, then click on the new row. Now click where it says "Disabed" in the new row, it will say it's waiting for a new shortcut key. I chose ctrl+F1
important: then log off and log back on again
voila! feedback, comment, suggestions appreciated
hwjp
  • 1,457
