15
I'm using Ubuntu 11.10 on my machine and I want to install some programs such as the windows program "proteus" and I can't install them on my machine.
I searched a lot and a lot for solution but have not found an acceptable answer. I don't have enough space to install windows beside of Linux. I also know that wine can run windows application but it doesn't work for me.
If any of you know alternative program for Proteus. I would appreciate that.
Salahuddin
  • 4,911
6 Answers6
If you are talking about the medical software; then this is a link to a Linux version:
http://www.proteme.org/download3.html
If you are talking a PCB design software the following are potential alternatives:
  • KiCad
  • PCB Designer
  • gEDA
  • Visolate
  • Fritzing
They are all available in the software center.
Pablo Bianchi
  • 17,371
cprofitt
  • 6,605
it runs ok on wine, no errors works great with my ATI adapter, and i've simulated PIC microcontroller on it all fine. ^^! just type in terminal
sudo apt-get install wine
First of all, it's sad to see some of the folks here suggest using wine or a virtual machine. Not only is it an inappropriate answer to the question, but also, in my humble opinion, it is against the spirit of the Ubuntu community to use and promote proprietary Windows software.
But back to your question, Proteus has two famous products Proteus PCB, which is an EDA suite (electronic design automation) and Proteus VSM for analog circuits and microcontroller (MCU) simulation. You did not mention which one you are referring to. Still, people usually look for VSM alternatives as it is a great software for simulating MCUs and the Arduino AVR development board. Unfortunately, there are not many cross-platform free, liquid, and open-source software (FLOSS) as powerful and feature-rich as Proteus VSM, but there are some attempts. I will try to list them here:
  • KTechLab
  • SimulIDE
  • BrainBox
  • PICsimLab or PICsim
  • PIC-Simulator
  • simavr
  • SimulAVR and simulavr-disp
  • SPICE (Simulation Program with Integrated Circuit Emphasis)
  • QUCS (Quite Universal Circuit Simulator), Qucs-S, Qucsstudio, Qucsator
  • Ngspice, Spice3f5, Cider1b1, and Xspice
  • Xyce
  • Circuit Simulator or CircuitJS1
P.S. I have created a curated list of all FLOSS electrical engineering software here.
Foad
  • 893
KTechlab will be a better alternative
Pablo Bianchi
  • 17,371
user147421
If you want, you can install Proteus 7.0 which is functional on Ubuntu 12.04 (32bits) with Wine or PlayonLinux. However, newer versions (7.5 or 8.0) won't work since wine finishes with errors during execution.
For your reading pleasure, here is my answer in French:
Salut, si tu veux encore installer Proteus-Isis, je te recommande la version 7.0 qui est fonctionnel sur ubuntu 12.04 avec Wine ou PlayonLinux.Cependant,pour les nouvelles versions (7.5 ou 8.0) Wine fini par des erreurs lors de l'exécution. Contente toi avec ce qui fonctionne sans te casser trop la tête, espérons que les prochaines mise à jours apporteront plus de liberté !
DrSAR
  • 2,132
Wine is good but not enough for such complex software as Proteus. I installed CrossOver (based on Wine), and install Proteus on it successfully.
