46
I have an Ubuntu 16.04 system with two interfaces - eth0 configured with DHCP and eth1 configured with static ip addresses.
The /etc/network/interfaces file has the following config
# The loopback network interface
auto lo
iface lo inet loopback
# The primary network interface
auto eth0
iface eth0 inet dhcp
# The Secondary network interface
auto eth1
iface eth1 inet static
address 10.10.1.10
netmask 255.255.255.0
dns-nameservers 74.82.42.42 4.2.2.2
## Virtual Interfaces for virtual hosts
auto eth1:11
iface eth1:11 inet static
address 10.10.1.11
auto eth1:12
iface eth1:12 inet static
address 10.10.1.12
auto eth1:13
iface eth1:13 inet static
address 10.10.1.13
The issue is, when DHCP server is not available on eth0 link or if the eth0 link is down, the system hangs for 5 mins, significantly slowing down the boot process.
violet@ubuntu-xenial:~$ systemd-analyze blame
      5min 241ms networking.service
          1.529s nmbd.service
          1.524s winbind.service
I tried reducing the time in /etc/systemd/system/network-online.target.wants/networking.service file which makes the system boot faster without waiting for the network service, however, that fails to load the virtual interfaces on eth1.
Is there a cleaner way to let the system boot without full network configuration on eth0 interface and still load all the static network configuration on eth1?
j202
  • 561
It seems someone was paranoid about a client not getting it's DHCP in time.
Edit this file /etc/dhcp/dhclient.conf and set timeout to a reasonable value, like
timeout 15
The default value of 300 seconds is way too high. The suggested replacement value of 15 was tested and works fine.
delfiler
  • 237
boutch55555
  • 1,226
29
So in your /etc/network/interfaces, change this:
auto eth0
to this:
allow-hotplug eth0
This will start interface eth0 when the kernel detects a hotplug event from the interface (i.e. when you plug a cable in), instead of starting it at boot.
guntbert
  • 13,475
As referenced in you can change the timeout value for raising the network interface (if running systemd):
Open a terminal window, and enter the command:
sudo nano /etc/systemd/system/network-online.target.wants/networking.service
Then change the line TimeoutStartSec=5min to a value that you choose. Save the file by pressing Ctrl+o and then Ctrl+x.
Finally, restart the daemon:
sudo systemctl daemon-reload
Ken Sharp
  • 1,086
Mike
  • 31
