I recently installed Ubuntu 16.04 LTS. Since I was facing the suspend bug, I installed a newer kernel as suggested here.
Even though the above mentioned link recommends to install kernel v4.4.8-wily, there seems to be even newer versions available here, such as v4.4.9-xenial, v4.4.10-xenial, v4.6-yakkety etc.
What is the maximum version that is compatible with Ubuntu 16.04 that will not introduce more bugs?
Also, just curious to know, what is the significance of the names after the hyphen -? How is v4.4.8-wily compatible with Xenial?
This might help: http://people.canonical.com/~kernel/info/kernel-version-map.html
Currently the lastest out of the box ubuntu 16.04 kernels are based on 4.4.8
Ex. 4.4.0-22.39 Ubuntu-4.4.0-22.39 4.4.8
You'd likely best be served by sticking with the kernel that comes with Ubuntu. If the AMD drivers are an issue I've heard others recommend sticking with 14.04
We can't say compatible/or not (for example v4.4.8-wily with Xenial). You can almost run any kernel on any release when when they have same major release (4) and somehow close minor release (4/7). The only difference is that *-xenial kernel releases had passed some QA/Tests prepared for same Xenial release, no more no less.
user.dz
  • 49,176
