Everything moves fine but when I try to intall the image from image store it shows some error rather than images any one can help me in solving it:
Error 60: server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none
César
  • 807
benson
Quick and insecure fix WARNING: the change disables certificate validation. Use at your own risk.
Until PycURL is fixed you can edit file /usr/lib/python2.6/dist-packages/imagestore/lib/fetch.py on fetch method after the line 142 add
curl.setopt(pycurl.SSL_VERIFYPEER, 0)
curl.setopt(pycurl.SSL_VERIFYHOST, 0)
Restart the image-store-proxy
And also update godaddy certificates:
sudo wget -P /usr/local/share/ca-certificates/ --no-check-certificate https://certs.godaddy.com/repository/gd-class2-root.crt https://certs.godaddy.com/repository/gd_intermediate.crt https://certs.godaddy.com/repository/gd_cross_intermediate.crt
sudo update-ca-certificates
