I have a lot of broken packages in my ubuntu 14.04 distro, which I am trying to fix.
I am following this answer by one of our community member. I followed the first two commands and after editing the file which he has mentioned I am not sure how can I determine which are the packages are broken and which one's to be removed.
When I am running apt-get install libmysqlclient-dev I am getting that broken packages issue.
Here's the result of running above command
 libmysqlclient-dev : Depends: libmysqlclient18 (= 5.5.49-0ubuntu0.14.04.1) but 10.0.25+maria-1~trusty is to be installed
Issue could be that I already have mariadb installed, although I am not sure how it got installed. I tried to remove it using the synaptic package manager but that didn't help.
Can someone please help me with that.I can share the chunk of that file If needed.
Suraj
  • 189
Here is what we have so far.
First, edit your /etc/apt/sources.list file and remove mariadb by executing the following commands:
sudo sed -i 's/^.*mariadb.*$//g' /etc/apt/sources.list
sudo apt-get update
Now, let's fix that broken package:
sudo apt-get install libmysqlclient18=5.5.49-0ubuntu0.14.04.1 libmysqlclient-dev
Please post any more errors, thanks.
mchid
  • 44,904
  • 102
  • 162
