I just try to install apache2 on my 14.04 Ubuntu server but I get an error:
 * Starting web server apache2        (98)Address already in use: AH00073: make_sock: unable to listen for connections on address [::]:80
(98)Address already in use: AH00073: make_sock: unable to listen for connections on address 0.0.0.0:80
no listening sockets available, shutting down
AH00015: Unable to open logs
Action 'start' failed.
The Apache error log may have more information.
 * The apache2 instance did not start within 20 seconds. Please read the log files to discover problems
invoke-rc.d: initscript apache2, action "start" failed.
Processing triggers for ureadahead (0.100.0-16) ...
Processing triggers for ufw (0.34~rc-0ubuntu2) ...
I try to access the log file at /var/log/apache2/access.log but the file's empty.
Please help me to solve this error. Thanks.
UPDATE: I get this to netstat -antp | grep 80
(No info could be read for "-p": geteuid()=1001 but you should be root.)
tcp        0      0 127.0.0.1:8080          0.0.0.0:*               LISTEN      -
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      -
tcp        0      0 0.0.0.0:8082            0.0.0.0:*               LISTEN      -
tcp        0      0 0.0.0.0:8001            0.0.0.0:*               LISTEN      -
tcp        0      0 127.0.0.1:5432          127.0.0.1:42080         ESTABLISHED -
tcp        0      0 127.0.0.1:42080         127.0.0.1:5432          ESTABLISHED -
tcp        0      0 127.0.0.1:41880         127.0.0.1:5432          ESTABLISHED -
tcp        0      0 127.0.0.1:53380         127.0.0.1:11211         ESTABLISHED -
tcp        0      0 127.0.0.1:38980         127.0.0.1:11211         TIME_WAIT   -
tcp        0      0 127.0.0.1:11211         127.0.0.1:53380         ESTABLISHED -
tcp        0      0 127.0.0.1:5432          127.0.0.1:41809         ESTABLISHED -
tcp        0      0 127.0.0.1:5432          127.0.0.1:41880         ESTABLISHED -
tcp        0      0 127.0.0.1:41809         127.0.0.1:5432          ESTABLISHED -
tcp6       0      0 127.0.0.1:8005          :::*                    LISTEN      -
Hhaevs
Run netstat as superuser to actually see the process that is using port 80 (like it is telling you basically).
sudo netstat -antp | grep 80
