24
I'm trying to install utorrent program, and when I execute the program I get
./utserver: error while loading shared libraries: libssl.so.0.9.8: cannot open shared object file: No such file or directory
I'm navigating the different forums since yesterday and I didn't find anything helpful till now, so please tell me what's the problem ??
αғsнιη
  • 36,350
5 Answers5
17
In general you should search for software through the software center or if you like the command line, you can use apt-cache search. In this case, the following package showed up (on 11.10): libssl0.9.8
You could try to install it (sudo apt-get install libssl0.9.8). If this does not help, you might want to tell us, which ubuntu version you are using.
xubuntix
  • 5,580
On Ubuntu 12.04 64bit version, it worked to install the 32 bit version:
sudo apt-get install libssl0.9.8:i386
But, of course, when you're on 32 bit Ubuntu, this should just work (without the :i386):
ayke
  • 469
If you are using 11.10 (since you did not mention it) you then have libssl1.0.0 which is higher than 0.9.8. Any program that needs 0.9.8 will also be able to handle versions above that one.
If you do NOT have 11.10 then you have several ways:
  1. Go to the OpenSSL site: http://www.openssl.org/ and follow installations there.
  2. Go to Ubuntu Packages and download the .DEB from there: http://packages.ubuntu.com/
  3. Go to Debian Packages and dowload the .DEB from there: http://www.debian.org/distrib/packages
  4. Install it via apt-get or aptitude:
    • sudo apt-get install libssl0.9.8 - For 0.9.8 Version
    • sudo aptitude install libssl0.9.8 - For 0.9.8 Version
    • sudo apt-get install libssl1.0.0 - For 1.0.0 Version
    • sudo aptitude install libssl1.0.0 - For 1.0.0 Version
Luis Alvarado
  • 216,643
Download package
http://archive.ubuntu.com/ubuntu/pool/universe/o/openssl098/libssl0.9.8_0.9.8o-7ubuntu3.1_i386.deb
Then install it
sudo apt install "libssl0.9.8_0.9.8o-7ubuntu3.1_i386.deb"
Just try this steps when you need it for CAV for Linux.
If you already tried to install cav but there is error with Libssl0.9.8:
  1. sudo apt-get --purge remove cav-linux
  2. Deinstall all libssl0.9.8 from/with Synaptic
  3. sudo apt-get clean
  4. sudo apt-get autoremove
  5. sudo aptitude install libssl0.9.8
and then install the normal way.
  1. Create a directory /opt/COMODO
    Copy cav file there:
    cd /opt/COMODO
    sudo dpkg -i cav-linux_1.1.268025-1_amd64.deb
  2. Download driver and rebuild driver
    copy them to /opt/COMODO
    run post setup:
    sudo /opt/COMODO/post_setup.sh
  3. Execute this only if you get an error that RedirFS modules are not installed
    sudo bash /opt/COMODO/fix_rebuild_driver.sh
  4. Reboot
techraf
  • 3,316
JDoerr
