Abstract:
Ubuntu detects wireless interface, but menu does not show any wireless network.
Details:
I have installed Ubuntu on MacBook pro early 2015. The appropriate drivers for my wifi are installed (according to this question WIfi Issues with Macbook Pro Retina Early 2015 (12,2) on Ubuntu 15.04). My device is
~$lspci -nn | grep 0280
03:00.0 Network controller [0280]: Broadcom Corporation BCM43602 802.11ac Wireless LAN SoC [14e4:43ba] (rev 01)
and it seems, that Ubuntu sees wireless interface
~$ sudo lshw -C Network
*-network
description: Network controller
product: BCM43602 802.11ac Wireless LAN SoC
vendor: Broadcom Corporation
physical id: 0
bus info: pci@0000:03:00.0
version: 01
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=wl latency=0
resources: irq:18 memory:c1400000-c1407fff memory:c1000000-c13fffff
*-network
description: Ethernet interface
product: NetXtreme BCM57762 Gigabit Ethernet PCIe
physical id: 0
bus info: pci@0000:0a:00.0
logical name: ens9
version: 00
serial: ac:87:a3:38:54:a8
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm vpd msi msix pciexpress bus_master cap_list rom ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=tg3 driverversion=3.137 duplex=full firmware=57762-a1.10 ip=130.223.51.185 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
resources: irq:19 memory:cda00000-cda0ffff memory:cda10000-cda1ffff memory:c1a00000-c1a0ffff
Therefore I do not get, why the menu with possible connection does not show any wireless networks (only Ethernet cable). I also installed next to unity KDE, and in the both cases, the list is blanc.
I also tried to install what is recommended here, Ubuntu can't detect wifi networks on macbookpro 13.3 but without any change of output (it is different wifi if I understood right, not wonder it has not worked).
