I am unable to install software using the Software Center at work. A nearly identical install of 11.10 at home works fine. I suspect the proxy settings are the problem, as they are used at work, but not at home. The system at work does browse the web and respond appropriately to nslookup's.
Asked
Active
Viewed 1.0k times
Create or edit /etc/apt/apt.conf defining your proxy configuration_
Acquire::http::Proxy "http://username:password@proxy_name_or_ip:port/";
Acquire::https::Proxy "https://username:password@proxy_name_or_ip:port/";
Acquire::ftp::Proxy "ftp://username:password@proxy_name_or_ip:port/";
You could ignore the username and password if you make no use of they, and you could ignore https or ftp in the same way.
This is based on a comment in a ticket reporting this issue.
jgomo3
- 716
Search for "network proxy" in Dash. Fill out your proxy details and set it system wide. Now, the software center can get the required packages via proxy server you set.
