I have a similar problem to this one:
Ethernet connection not working after installing Ubuntu 14.04 LTS
I also have a dual boot with windows 7 and ubuntu 14.04. My ethernet connection has always been fine in ubuntu. I recently booted to windows 7 for the first time, and connection was still fine. The problem came when I booted back into ubuntu, with no connection being picked up.
Unfortunately I can't post the diagnosis info since I can't connect the machine to the internet, but from what I can tell the only major difference is that when I run
sudo lshw -class bridge
my "driver" comes up as e1000e and not as "forcedeth".
Hence, when I try @ElderGeek's solution (as root in the recovery mode), the line
rmmod forcedeth
returns something like
ERROR: Forcedeth not currently loaded
most likely since that's not even a driver.
I imagine that the answer is probably just to instead try
rmmod e1000e
modprobe e1000e msi=0 msix=0
exit
but I don't want to run commands that I don't fully understand in case I break something.
(Although I suppose it wouldn't matter if it's booted into recovery mode?)
EDIT - additional information
~ $ lspci | grep Ethernet
00:19.0 Ethernet controller: Intel Corporation Ethernet Connection I217-LM (rev 04)
~ $ ifconfig eth0
eth0 Link
encap:Ethernet HWaddr 64:00:6a:4d:d0:dc
BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:20 Memory:f7d00000-f7d20000
~ $ sudo lshw -class bridge
*-pci
description: Host bridge
product: 4th Gen Core Processor DRAM Controller
vendor: Intel Corporation
physical id: 100
bus info: pci@0000:00:00.0
version: 06
width: 32 bits
clock: 33MHz
configuration: driver=hsw_uncore
resources: irq:0
*-pci
description: PCI bridge
product: Xeon E3-1200 v3/4th Gen Core Processor PCI Express x16 Controller
physical id: 1
bus info: pci@0000:00:01.0
version: 06
width: 32 bits
clock: 33MHz
capabilities: pci pm msi pciexpress normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:26 ioport:e000(size=4096)
memory:f7c00000-f7cfffff ioport:e0000000(size=268435456)
*-isa
description: ISA bridge
product: Q87 Express LPC Controller
physical id: 1f
bus info: pci@0000:00:1f.0
version: 04
width: 32 bits
clock: 33MHz
capabilities: isa bus_master cap_list
configuration: driver=lpc_ich latency=0
resources: irq:0
~ $ sudo lshw -class network
*-network DISABLED
description: Ethernet interface
product: Ethernet Connection I217-LM
physical id: 19
bus info: pci@0000:00:19.0
logical name: eth0
version: 04
serial: 64:00:6a:4d:d0:dc
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=3.3.3-NAPI duplex=full firmware=0.13-4 latency=0 link=no multicast=yes port=twisted pair speed=100Mbit/s
resources: irq:29 memory:f7d00000-f7d1ffff memory:f7d3d000-f7d3dfff ioport:f080(size=32)
~ $ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu Description:
Ubuntu 14.04.4 LTS
Release: 14.04
Codename: trusty
