I have a laptop whose hard drive has failed (beeps upon startup and displays "no boot device"). I would like to install Ubuntu from a live USB onto another USB, from which I will boot the computer in the future. I created a live USB with a flash drive formatted to FAT32 on a Mac computer using unetbooting. It has 14.04.4 on it. I have unplugged the harddrive and removed the tray from the target computer (Lenovo ideapad u430).
My steps:
Upon inserting the live USB and the empty 16 GB USB (also formatted to FAT32) into the laptop, I am taken to a Ubuntu menu.
I click the option "install Ubuntu."
I immediately given the message:
"error: invalid magic number.
alloc magic is broken at 0x94e4a440: 94d69540
Aborted. Press any key to exit."
This is all that happens. I have tried this exact process with 16.04 and I get the same results; I am fairly confident that the USB was set up properly in each case. I am very much a newbie and do not know what to try from here. I appreciate any and all help you guys may have to offer.
Aaron
  • 6,764
SethO
  1. Did you md5sum check the downloaded ISO file? See https://help.ubuntu.com/community/HowToMD5SUM Check the number against the listing in the link for your release listed at http://releases.ubuntu.com under the MD5SUMS link.
  2. If using a CD/DVD, did you burn the disc as slowly as possible? See https://help.ubuntu.com/community/BurningIsoHowto
  3. Did you select the media check before trying to install? https://help.ubuntu.com/community/Installation/CDIntegrityCheck
  4. Did you ever do a "memory check" (perhaps another live-media menu choice) on your PC?
Doing the above can save you a lot of time struggling with a bad install media.
ubfan1
  • 19,049
