I have two scripts:
  1. in bash
    #!/bin/bash
    H_VARIABLE=empty
    echo "Zeile1
          Zeile2" |
    while read satz
     do
      H_VARIABLE="$H_VARIABLE $satz"
    done
    echo H_VARIABLE=$H_VARIABLE
    Result:
    H_VARIABLE=empty
  2. in ksh
    #!/usr/bin/ksh
    H_VARIABLE=leer
    echo "Zeile1
          Zeile2" |
    while read satz
     do
    done
    Result:
    H_VARIABLE=leer Zeile1 Zeile2
Conclusion: leer Zeile1 Zeile2 != leer
What can I do in bash to get the same response as in ksh?
muru
  • 207,228
The issue here is that, in bash, the while loop gets executed in a subshell when it is on the RHS of a pipe. You could do instead
H_VARIABLE=leer
while read satz
  do H_VARIABLE="$H_VARIABLE $satz"
done < <(
echo "Zeile1
      Zeile2"
using process substitution or, using a here string
H_VARIABLE=leer
while read satz
done <<< "Zeile1
          Zeile2"
See also bash script var not changed after the loop
steeldriver
  • 142,475
