I've successfully configured four workspaces by using the switcher applet, but I can't find where to configure shortcuts (like ctrl+alt+left to move to the one on the left).
Some resources says it should be under Preferences > Keyboard Shortcuts, but I can only find entries for Sound, Desktop (including lock screen, home folder, search, calc and other apps) and Custom ones.
Is something missing in my install? Is it possible to include by hand those shortcuts? Should I just ditch MATE workspaces and use Compiz ones (that do not integrate with the windows applet)?
These settings are normally found in Keyboard Shortcuts:
System > Preferences > Hardware > Keyboard Shortcuts
https://roseannastar.files.wordpress.com/2016/08/keyboardshortcuts.png
Click where it shows the key combo or says 'disabled' and press the key combination you want.
If you cannot use this feature for some reason or you prefer a CLI method, use Gsettings.
Here are all the possible keybindings for workspace manipulation and their likely default values:
org.mate.Marco.global-keybindings switch-to-workspace-left '<Control><Alt>Left'
org.mate.Marco.global-keybindings switch-to-workspace-11 'disabled'
org.mate.Marco.global-keybindings switch-to-workspace-10 'disabled'
org.mate.Marco.global-keybindings switch-to-workspace-1 'disabled'
org.mate.Marco.global-keybindings switch-to-workspace-12 'disabled'
org.mate.Marco.global-keybindings switch-to-workspace-4 'disabled'
org.mate.Marco.global-keybindings switch-to-workspace-2 'disabled'
org.mate.Marco.global-keybindings switch-to-workspace-3 'disabled'
org.mate.Marco.global-keybindings switch-to-workspace-7 'disabled'
org.mate.Marco.global-keybindings switch-to-workspace-5 'disabled'
org.mate.Marco.global-keybindings switch-to-workspace-6 'disabled'
org.mate.Marco.global-keybindings switch-to-workspace-8 'disabled'
org.mate.Marco.global-keybindings switch-to-workspace-prev 'disabled'
org.mate.Marco.global-keybindings switch-to-workspace-right '<Control><Alt>Right'
org.mate.Marco.global-keybindings switch-to-workspace-9 'disabled'
org.mate.Marco.global-keybindings switch-to-workspace-down '<Control><Alt>Down'
org.mate.Marco.global-keybindings switch-to-workspace-up '<Control><Alt>Up'
org.mate.Marco.window-keybindings move-to-workspace-8 'disabled'
org.mate.Marco.window-keybindings move-to-workspace-10 'disabled'
org.mate.Marco.window-keybindings move-to-workspace-12 'disabled'
org.mate.Marco.window-keybindings move-to-workspace-11 'disabled'
org.mate.Marco.window-keybindings move-to-workspace-left '<Control><Shift><Alt>Left'
org.mate.Marco.window-keybindings move-to-workspace-down '<Control><Shift><Alt>Down'
org.mate.Marco.window-keybindings move-to-workspace-1 'disabled'
org.mate.Marco.window-keybindings move-to-workspace-2 'disabled'
org.mate.Marco.window-keybindings move-to-workspace-3 'disabled'
org.mate.Marco.window-keybindings move-to-workspace-4 'disabled'
org.mate.Marco.window-keybindings move-to-workspace-5 'disabled'
org.mate.Marco.window-keybindings move-to-workspace-6 'disabled'
org.mate.Marco.window-keybindings move-to-workspace-7 'disabled'
org.mate.Marco.window-keybindings move-to-workspace-9 'disabled'
org.mate.Marco.window-keybindings move-to-workspace-up '<Control><Shift><Alt>Up'
org.mate.Marco.window-keybindings move-to-workspace-right '<Control><Shift><Alt>Right'
org.mate.Marco.window-keybindings toggle-on-all-workspaces 'disabled'
To change one use the gsettings set command, for example
gsettings set org.mate.Marco.window-keybindings move-to-workspace-3 '<Mod4>3'
This command sets super+3 as a shortcut to move the current window to workspace 3.
To remove a keybinding, set it to 'disabled'. See man gsettings for more detail. You may have to experiment to achieve exactly what you want.
Zanna
  • 72,312
