When trying to install any package in a terminal, I get the following error
Not possible to block /var/lib/dpkg/lock - open (11: Temporaly not available resource )
This started happening after trying to install Microsoft font libraby. It stopped at:
"ttf-mscorefonts-installer" configuration window
Tim
  • 33,500
Gal
This has already been answered - Unable to lock the administration directory (/var/lib/dpkg/) is another process using it?. Just run:
sudo fuser -cuk /var/lib/dpkg/lock; sudo rm -f /var/lib/dpkg/lock
Yuval A
  • 307
Hey the problem is simple probably your previous installation of software was interrupted.Hence the lock file is still locked by the previous installation.Do this thing it may help try again to install the software ,if still the error comes then reboot the system and try the software center to install a software.
coder
  • 3,691
